Pulling in files from External Sources
Re: Pulling in files from External Sources
Thanks for ALL your assistance with this AIFF problem, Sami32
I will have a root around on the internet to see if it might throw up some answers
Fingers crossed that the new UMS will sort out matters anyway.
Take Care
miklos
Take Care
miklos
The DMG file is an ISO file so you shouldn't replace the FFMpeg executable with that one. But, if you open the DMG file you will find a FFMpeg executable inside. Copy that version over the one used by UMS "/Applications/Universal Media Server.app/Contents/Resources/osx/ffmpeg". As to browsing to that folder, I'm not very familiar with "Finder" or whatever you use for this, but you should be able to navigate there if you navigate from "Root"?
In any case, it's easy to copy it using "cp <from> <to>" in terminal.
