Pulling in files from External Sources
There is probably an easy answer to this - it isn't possible - but thought I would ask.....
I am currently using UMS 5.2.3 - I know that this is an old version, but if it works I am loathe to tinker because I had earlier problems with UMS recognising my Marantz machine.
Is it possible to pull into the Navigation/Share Settings (Shared Folders) files (mp3, aiff, flac, etc) from an external Hard-Drive rather than those stored on the actual computer?
UMS currently streams everything beautifully that is on my computer's Hard-Drive out to my Marantz machine but I can't get anything stored elsewhere to appear in the drop-down Directory menu at Shared Folders.
I am on a Mac - if that helps (or not as the case might be).
Cheers
Cheers
Re: Pulling in files from External Sources
Well, I'm on a PC, but it should be the same, I would think. You can add locations from external hard drives and even network locations. I actually add the drive letters of possible external drives, and they show up if connected. I can connect it after UMS is started, and just restart UMS and It will show up. If it's not connected, UMS complains in the log, but it's harmless. You can do the same with your optical drive. So the number of locations that show up for me depends on what I have on.
Thanks Modoka & squadjot for your input.
Following the instructions at 'viewtopic.php?f=11&t=7708' I was able to identify the external drive OK and select FOLDERS.
Both FLAC & MP3 read fine but AIFF files don't seem to be streamed over - message on the Marantz reads FILE FORMAT ERROR.
Is it because I am using an older version of UMS that AIFF files don't seem to be recognised?
Or are AIFF's not recognised, fullstop!
Any further help would be much appreciated.
Cheers
Miklos
Cheers
Miklos
Could you post one of your AIFF file sample here ?
Are they playing fine from USB ?
Hi Sami32
How do I post a sample file in this message? Can't load the aiff file direct into the message unfortunately.
'aiff' files just don't register (this is the case on both external USB Hard-Drives or the Mac's own Hard-Drive).
I don't have any problem retrieving MP3, FLAC or WAV files from External or on the Mac's HD.
Cheers
Miklos
Cheers
Miklos
Do you mean that your AIFF files doesn't play from your USB plugged in your Marantz ?
What do you mean by AIFF files doesn't register ? You cannot see or play them on your MAC ? your cannot see them in UMS ?
For posting an little AIFF file here, you'll need to attach it with a fake supported extension as .txt for example.
Or if it's too big, post the link where it can be downloaded as Wetransfer for example.
Thanks for your reply, Sami32
All formats (including AIFF) play fine when plugged directly into the Marantz via a USB stick, I-Pod, etc.
AIFF files plays OK on the Mac. When locating folders containing AIFF files via UMS - they appear greyed out.
Attached (hope the fake extension works!) is a typical AIFF file that isn't recognised (FILE FORMAT ERROR message) when trying to access it via UMS through my Marantz machine.
Cheers
Miklos
Cheers
Miklos
Does the file play with the [No Encoding] option from the #--transcode--# folder?
Thank you for the sample Miklos. It look standard, well formed file to me, so it's look like your log will be helpfull.
Just follow these simple steps and post your full TRACE log:
viewtopic.php?f=9&t=556
As i saw other similar issue like that only for MAC users, that could be a specific issue that will need your log as i'm don't own a MAC for testing it myself...
