Channels not showing up?
When i installed channels, I put my .ch files in /%umsdirectory%\channels\
When i start it up and scan through my channels folder, There is no channels to be found!
Only 5 folders, default stuff, And here is my channels log.
04:34:52.980 Started 2.20
04:34:53.015 [Channel] starting
04:34:53.031 [Channel] parsing channel file C:\Program Files\Universal Media Server\channels\1channel.ch version unknown
04:34:53.065 [Channel] parsing channel file C:\Program Files\Universal Media Server\channels\icefilms.ch version unknown
04:34:53.101 [Channel] parsing channel file C:\Program Files\Universal Media Server\channels\navix.ch version unknown
04:34:53.112 [Channel] parsing channel file C:\Program Files\Universal Media Server\channels\youtube.ch version unknown
04:34:53.120 [Channel] No navix upload playlist configured
04:34:53.126 [Channel] using save path
04:34:53.126 [Channel] Set chanelpath to C:\Program Files\Universal Media Server\channels
04:47:37.716 [Channel] fpage cookie
04:47:37.717 [Channel] fpage2 cookie file:/C:/Program%20Files/Universal%20Media%20Server/channels/data/navix_local.plx
04:47:37.718 [Channel] fetch exception java.io.FileNotFoundException: C:\Program Files\Universal Media Server\channels\data\navix_local.plx (The system cannot find the file specified)
04:47:37.718 [Channel] navix page
Kader_Citoyen
Re: Channels not showing up?
Hey guys,
I would love to have some sort of help setting up my navi-x channels for ums.
Im a newbie, configured xbmc on my comp easily and installed navi-x no problems there.
I'm just wondering what to do to have the channels (most viewed 24h for example) pop up on my ps3.
Thanks !
EDIT : I kind of hijacked this older post because I have the same problem...I rather try this then re create another post for what seems to be the same problem. Except I tried to play ted talk, and it worked perfectly for me. I just want to be able to stream the same content as my PC.
Kader
Thanks !
Kader
