USM transcoding mp4 to mjpeg.
Hi. I have some videos in mp4/h264 format. When using mkv my h264 files plays perfectly well but with mp4 UMS only displays the files as JPG and I see ffmpg started to transcode to mjpeg. Incidentally my TV do not support mjpeg. Converting all mp4 files to mkv isn't a very convenient solution to this problem. How do I disable transcoding?
Re: USM transcoding mp4 to mjpeg.
The first thing you need to do is to read the text in red above. The problem is probably with your renderer configuration, but it could also be a bug. Impossible to know without further information.
