v3 Database - 2 instances of UMS ?
With previous versions, starting 2 instances of UMS with different "conf" files, different UDI, IP-port, etc
worked very well and it was also possible to enable the "cache feature".
It seems as if the mediadatabase in ver3 has moved to the doc and settings path instead of directly below
the UMS installed path. Because of that, enabling the cache for 2 instances of UMS doesn't seem to work that
great.....which makes sence.
Can't find any setting in the conf files or otherwise to specify where the media-db should be,
so, any tips ?
Thanks,
so, any tips ?
Thanks,
