Movies freezing close to finish
I'm using Mirascreen's dongle as renderer on my TV with the basic configuration:
SeekByTime = exclusive
TranscodeAudio = MP3
MaxVideoBitrateMbps = 20
Max buffer size = 400 MB - In global settings
When I'm watching .mkv episodes (about 23:35 min each one) after the renderer plays 23:31 min the buffer bar just appears and doesn't load anymore, the episode is paused and frosted. After checking in UMS I could see that the blue bar and Actual Bitrate (from transcoding) are off while the Bitrate peak goes crazy reaching 3000 Mb/s with the movie stopped.
I looked into the logs and noticed that the problem occurs a few seconds after the buffer being destroyed, so, maybe I should increase the buffer time to avoid it but I didn't find anything related to it and I'm not sure if this is a solution.
