Search terms
Search terms
The forum search function is sometimes is a bit of a nanny, for instance if you search for "xbox" it tells you:
and similarly for 'xbox 360', 'sony' and others. Can this unhelpfulness be turned off?The following words in your search query were ignored because they are too common words: xbox.
You must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 14 characters excluding wildcards
Re: Search terms
I too wondered if that was by design or not....
Universal Media Server Wiki!
- Optimus_prime
Re: Search terms
It's a limitation of phpbb i think. Subjunk's in charge of all the website admin stuff, so i can't help there
Re: Search terms
Boooooo
Re: Search terms
Hopefully fixed this now
Re: Search terms
Yeah xbox is searchable now thank bro!
Re: Search terms
Looks like this issue is back, possibly due to recent forum upgradeSubJunk wrote:Hopefully fixed this now
