Java Runtime Enviroment 7.0+
marc26rpg7
So I downloaded UMS and when I try to run it I get a message that says that UMS requires Java Runtime Enviroment 7.0+ , I click ok and I get a message that says download failed, failed to open (java directory).
Re: Java Runtime Enviroment 7.0+
You need to have Java 7 or Java 8 installed to run UMS. Java 9 is also said to work, but the UMS Windows installer doesn't currently "detect" Java 9 so it will try to download another Java version.
marc26rpg7
Thanks, I downloaded the most recent version of Java and it's working fine now.
