HTTPS ?
Re: HTTPS ?
@Seladian there is not docummented feature in the UMS.conf. Add the to the UMS.conf and test it.
use_https=trueRe: HTTPS ?
It doesn't work ..
I follow that instruction:
1. Generate certificate using keytool: keytool -genkey -keyalg RSA -alias selfsigned -keystore UMS.jks -storepass password -validity 360 -keysize 2048
2. Copy UMS.jks (passowrd: umsums) to UMS folder
3. In UMS.conf I add: use_https=true
4. Restart UMS
and.. connection doesn't work. I don't know why.
4. Restart UMS
Re: HTTPS ?
@Seladian I don't know how the HTTPS was implemented by former UMS/PMS developers I only found the undocummented setting to enable it.
