Samsung KU6000 Series 6 4k Playback issue
rowdyruffbrick
Post by rowdyruffbrick »
Hey guys,
I know samsung 4k tv threads have been up quite often but I still cant seem to get it right. My 65" KU6000 tv is having issues playing my 4k files:
-the audio is faster than the picture
-It buffers every few seconds
-at a certain point when it sorta plays smoothly, the picture just stutters totally with no sound at all.
I have attached my logs, since the normal one didnt work I used this renderer from this thread viewtopic.php?t=8887
the same results ensued. Im not sure if its my computer issue or something else. Really hope someone can help me on this. Thanks in advance.
(121.04 KiB) Downloaded 535 times
valib
Re: Samsung KU6000 Series 6 4k Playback issue
Post by valib »
Try attached conf. In the original Samsung-UHD.conf were wrong settings. "aac" instead of "aac-lc" and "aac-he" instread of "he-aac". That is why your video is transcoded with all that side effects. Transcoding 4k video on the fly is really CPU demanding task.
In your log I see that some audio formats are not recognised like for video
ndhaIDFL.EuropaLeague.Liverpool.vs.BorussiaDortmund.14.04.2016.720p.QuarterFinal.2ndLeg.English.2ndHalf.mkv
Can you provide the MediaInfo for that file?
Samsung-UHD (1).conf
(6.53 KiB) Downloaded 563 times
rowdyruffbrick
valib wrote: ↑Sat Feb 17, 2018 9:14 pm Try attached conf. In the original Samsung-UHD.conf were wrong settings. "aac" instead of "aac-lc" and "aac-he" instread of "he-aac". That is why your video is transcoded with all that side effects. Transcoding 4k video on the fly is really CPU demanding task.
Thanks for the help! unfortunately even with the new renderer i still face the same issues. I have played more files this time just to see if the problem can be found easier. Also one of the files couldnt be played at all and there was a check your internet connection error while trying to play it.
And I'm not sure if this is the information youre looking for but it's audio codec is mp4a.
Attached is the log for the bug.
(225.15 KiB) Downloaded 503 times
valib
Post by valib »
I realy like to see the MediaInfo output for that video to see why is the audio format not recognised.
rowdyruffbrick
valib wrote: ↑Mon Feb 19, 2018 1:49 am I realy like to see the MediaInfo output for that video to see why is the audio format not recognised.
Sorry, how do I obtain that? Apologies really bad at this stuff.
valib
Post by valib »
You have to install MediaInfo from this page https://mediaarea.net/en/MediaInfo open the media file and set the MediaInfo to text view. Then you can either export the result or simply copy the text from the view and put it here.
rowdyruffbrick
valib wrote: ↑Mon Feb 19, 2018 3:20 am You have to install MediaInfo from this page https://mediaarea.net/en/MediaInfo open the media file and set the MediaInfo to text view. Then you can either export the result or simply copy the text from the view and put it here.
Alright here you go:
General
Unique ID                                : 177164215419890683632057382503387982238 (0x85489635951DBA0E8332F9889883699E)
Complete name                            : D:\ndhaIDFL.EuropaLeague.Liverpool.vs.BorussiaDortmund.14.04.2016.720p.QuarterFinal.2ndLeg.English.2ndHalf.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 785 MiB
Duration                                 : 51 min 20 s
Overall bit rate                         : 2 138 kb/s
Encoded date                             : UTC 2016-04-14 23:27:56
Writing application                      : mkvmerge v6.4.1 ('Omega Point') built on Sep 16 2013 22:05:10
Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L3
Format settings                          : 1 Ref Frames
Format settings, CABAC                   : No
Format settings, RefFrames               : 1 frame
Codec ID                                 : V_MPEG4/ISO/AVC
Nominal bit rate                         : 2 000 kb/s
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 50.000 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.043
Writing library                          : x264 core 116 r2019 9cc407d
Encoding settings                        : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=2000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default                                  : Yes
Forced                                   : No
Audio
Format                                   : AAC
Format/Info                              : Advanced Audio Codec
Format profile                           : Main
Codec ID                                 : A_AAC-1
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 44.1 kHz
Frame rate                               : 43.066 FPS (1024 SPF)
Compression mode                         : Lossy
Default                                  : Yes
Forced                                   : No
valib
Post by valib »
It seems to me like a bug in the UMS.
@valib I think the AAC "Main" profile is pretty rare and not very well supported. I don't remember hos we handle it, but it's neither AAC-LC or HE-AAC.
rowdyruffbrick
valib wrote: ↑Tue Feb 20, 2018 2:22 am It seems to me like a bug in the UMS.
Is this file affecting the playback of the 4k files?
