[HOWTO] install ums in a jail via thebrig in Nas4Free (BSD)
I write a Howto install ums in Nas4Free Forums.
you can see here: http://forums.nas4free.org/viewtopic.php?f=79&t=5221
Because Nas4Free is BSD , install probably work on FreeNAS or several BSD Flawours.
PD: I still work on a BSD script to start properly ums, I use BSD script for serviio (java based) to adapt it to ums, but still no luck.
NOTICE for ums developer: ums is a great DLNA/UPnP player but have problems to install on headless machimes, can be really usefull if new compile use excelent ums-webinterface from ntrp user: https://bitbucket.org/ntrp/ums_webinterface/wiki/Home
I found first time here: viewtopic.php?f=6&t=976&p=5960#p5960
Jabberwocky
Re: [HOWTO] install ums in a jail via thebrig in Nas4Free (B
I have some isues when I try to install inside new jail (nas4free)
1)
No mediainfo an zen libs found. I install media info package and search files inside ums jail folder but can't find them.
2)
I start the ums service via SH in terminal, I cant see only for a few seconds in Android device, enter and play files ok. But when I exit from android an search for the ums server I can't see it any more, terminal seems still runing ums, also web ui seams be ok. But I can't access or see the ums server in any device.
Any help????
P.d. sorry for my bad english.
1)
2)
Any help????
fhenning09
How Do I get UMS to display subs on Samsung Smart Tv's? I understand the question is unique just wondering if anyone has had similar prob and found their own solution?
