Looking For Some Help Streaming UHD to PS3
jstuart777
Post by jstuart777 »
Hi there all,
I just recently got a new VIZIO E-Series SMART TV
And I would like to be able to stream UHD movies on it.
I can very clearly stream 1080p movies with no problem.
I have finally been able to get the UHD movies to play but
I can tell that it is NOT in UHD.
Any help that anyone could suggest is greatly appreciated.
I also do have a PS4 if anyone has a reliable way to do this
with a PS4
The network is wired
WINDOWS 10 64 bit
Quad Core 3.30ghz
8 gb ram
If there's anything else I can post that will help anyone willing
to assist me just let me know. I'm usually pretty quick in responding
Thank you
jstuart777
debug.log
(140.28 KiB) Downloaded 852 times
Re: Looking For Some Help Streaming UHD to PS3
What make you think that the PS3 can handle UHD? https://www.quora.com/Does-PS3-support-4k-resolution
jstuart777
Hey there,
Other articles I've come across in this forum has said
that they have done it.
I don't care if it's PS3 or PS4.
I'll take what works :)
jstuart777
There are many threads about the PS4, I don't have one myself and I know that there are all kind of issues with the PS4 and all the different versions. You should be able to find what you need to enable it you search the forum. I'm not sure about this, but I think the reason it's not enabled by default in UMS' configuration is that not all PS4's can handle it.
jstuart777
Thank you. I am looking to make this work
as far as i know you will only be able to stream UHD on PS4 pro and not a normal PS4 or PS3 (i'm guessing the topic title is a typo though)
