[Solved] Renderer disconnecting from UMS
GIVEMEANACCOUNT
Hi all,
My PS4 disconnect after 20-30 ]minutes from the server. I looked around and it seemed like this was a common issue.
So I tried everything i've seen in those post and nothing helped.
Things I tried were:
I also thought my Network might be an issue so let me try to explain it.
I've a Router/modem downstairs that runs an ethernet cable to my own router upstairs. The routers wireless mode is set to Acces Point. My computer is connected to the router through a cable and my PS4 is connected through WIFI.
There's a big chance im missing something obvious.
Thanks for your help
- Static-IP
- Reinstalling Java
- Downgrading to 6.8
- Removing the IPv4 line from the UMS.bat file and starting it up with the bat file
- Multiple clean installs
- (69.34 KiB) Downloaded 462 times
Last edited by GIVEMEANACCOUNT on Fri May 25, 2018 8:53 am, edited 1 time in total.
Re: Renderer disconnecting from UMS
You set . Please leave it empty and let UMS recognise all renderers.
renderer_default: "PlayStation 4"-
GIVEMEANACCOUNT
Oh yeah I did was one of the things I tested out to try and fix it.
GIVEMEANACCOUNT
I've found a solution (thank god). I wired my PS4 to my router and that seems to do the trick. Still pretty weird it didn't work before tho.
