Data file not supported - problem with Hi444PP?
Hello there, firstly I would like to thank you for such a great application, which is UMS. You are doing there great work.
Here is sample of this particular file:
http://bit.ly/16qd1UE
I've problem playing one particular .mkv file, which always give me "data file not supported" error on my PS3. It occurs when I'm trying to play it with MEncoder. File is not corrupted, it's playing perfectly fine on my iMac. I tried playing it without subtitles ,without dts passthrough and changing buffer size, with no luck. Problem occurs with UMS 2 and 3, also PS3 Media Server.
Can it has something to do with Hi444pp?
Would be grateful for any advice how to run it.
I'm attaching debug.zip
OSX 10.8
Also, playing any movie with UMS, lower black bar is constantly "moving" up-down, it looks like its frame is blinking. I did not have this problem with PS3 Media Server
OSX 10.8
- (38.06 KiB) Downloaded 506 times
