Trying to run on Headless Machine (server)
puntloos
Post by puntloos »
Running UMS on an actual server... The error message complains about graphics. Not available, obviously. Elp? :/
/opt/local/ums-1.3.0 # ./UMS.sh
06:50:03.771 [main] DEBUG o.a.c.c.PropertiesConfiguration - FileName set to UMS.conf
06:50:03.790 [main] DEBUG o.a.c.c.PropertiesConfiguration - Base path set to /root/.config/UMS
06:50:04,338 |-INFO in ch.qos.logback.core.joran.action.DefinePropertyAction - About to instantiate property definer of type [net.pms.logging.DebugLogPathDefiner]
06:50:04,355 |-INFO in ch.qos.logback.core.joran.action.DefinePropertyAction - Popping property definer for property named [debugLogPath] from the object stack
06:50:04,356 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
06:50:04,356 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [STDOUT]
06:50:04,521 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.FileAppender]
06:50:04,524 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [debug.log]
06:50:04,535 |-INFO in ch.qos.logback.core.FileAppender[debug.log] - File property is set to [/opt/local/ums-1.3.0/debug.log]
06:50:04,538 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - About to instantiate appender of type [ch.qos.logback.core.rolling.RollingFileAppender]
06:50:04,541 |-INFO in ch.qos.logback.core.joran.action.AppenderAction - Naming appender as [debug.log.10MB]
06:50:04,578 |-INFO in ch.qos.logback.core.rolling.FixedWindowRollingPolicy@19e15c - Will use zip compression
06:50:04,603 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[debug.log.10MB] - Active log file name: /opt/local/ums-1.3.0/debug.log
06:50:04,603 |-INFO in ch.qos.logback.core.rolling.RollingFileAppender[debug.log.10MB] - File property is set to [/opt/local/ums-1.3.0/debug.log]
06:50:04,603 |-INFO in ch.qos.logback.classic.joran.action.RootLoggerAction - Setting level of ROOT logger to ALL
06:50:04,604 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [STDOUT] to Logger[ROOT]
06:50:04,604 |-INFO in ch.qos.logback.core.joran.action.AppenderRefAction - Attaching appender named [debug.log] to Logger[ROOT]
06:50:04,604 |-INFO in ch.qos.logback.classic.joran.action.ConfigurationAction - End of configuration.
ERROR 2012-07-10 06:50:05.057 [main] A serious error occurred during PMS init
java.awt.HeadlessException: null
        at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:159) ~[na:1.6.0_32]
        at java.awt.Window.<init>(Window.java:431) ~[na:1.6.0_32]
        at java.awt.Frame.<init>(Frame.java:403) ~[na:1.6.0_32]
        at java.awt.Frame.<init>(Frame.java:368) ~[na:1.6.0_32]
        at javax.swing.JFrame.<init>(JFrame.java:158) ~[na:1.6.0_32]
        at net.pms.gui.DummyFrame.<init>(DummyFrame.java:25) ~[ums.jar:na]
        at net.pms.PMS.init(PMS.java:310) [ums.jar:na]
        at net.pms.PMS.createInstance(PMS.java:804) [ums.jar:na]
        at net.pms.PMS.main(PMS.java:877) [ums.jar:na]
timmyj
Re: Trying to run on Headless Machine (server)
Post by timmyj »
i think headless mode is broken on 1.3.0 had to downgrade to 1.2.1 to restore functionality on my headless server
nox216
Post by nox216 »
Same issue with headless being broken on 1.3.0. Downgraded to 1.2.1, issue resolved.
I think we have narrowed down what caused this bug, it should be fixed in the next version
jmarler
Post by jmarler »
+1 for needing the fix for headless.
One other issue I recently tracked down. .mkv files wouldn't render, and when I looked in the debug.log it ended up that it couldn't find the tsMuxer binary. I symlinked to it in /usr/bin and the problem disappeared. I may have missed something in the install instructions, but I thought I would mention it.
PS -> Thanks big time for all your hard work! It felt like PMS was stalled and going nowhere. I really like the progress you are making.
puntloos
Post by puntloos »
As an aside, how does one set the config path in the startup script?
"Base path set to /root/.config/UMS" is a bit wonky."
Also, if you will excuse my laziness but a quick search did not show it up - is there any way to access a GUI-based control panel to UMS with a headless and windowless server? (I am using a NAS, so I can't just run VNC and then run UMS from within.. I really want to separate the client from the server)
splinter
Post by splinter »
puntloos wrote:As an aside, how does one set the config path in the startup script?
Kind regards to all
There has been some success with the freenas end reported - I have not experianced it yet but I am considering that direction on my next major upgrade trying to work towards to ZFS as my hardware reaches the capability to make it a reality.
http://www.homemultimedianetwork.com/Gu ... reeNAS.php :?:
Again kind regards to all in the forum as I have enjoyed the fruits of this build prior to it forking out.
Splinter
martinoelge
Post by martinoelge »
hey,
what a mess to place a different software in a thread like this... anyway...
Whats about installing UMS on a headless device?
I ran PS3 on my ReadyNAS since a couple of years...
it neads an update? doesn't it?
Martin
sapsa
Post by sapsa »
Im using headless installation (UMS 3.0.0-final) on ubuntu server 13 64bits, and it works ok.
Had crashed because of low memory, but i changed it to 1024MB and will check in few days.
Im having few issues with hardcore encoded files :-) with exotic profiles etc.. but with others there is no problem on wired link
Theres no need for GUI now :-) its harder do config on start but after that gui would be useless.
server: C2D E6750@2.66GHz 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
