[Solved] UMS conflicts with IBM sametime
atamariya
Post by atamariya »
Please note that UMS conflicts with IBM sametime on the same machine - both of the use port 5001. One quick fix is to add port configuration in UMS.conf
port = 5002
Re: [Solved] UMS conflicts with IBM sametime
I wonder if there is any reason we can't just change our default port other than users with port forwarding would need to update it
