UMS Just won't boot up
fullmetalraz
I have installed the proper version, uninstalled Java, uninstalled and reinstalled the program... deleted the database... it just always hangs on the splash screen I have never gotten it to successfully boot up. Any help would be advised.
Re: UMS Just won't boot up
Hi fullmetalraz, sorry to hear you're having problems starting UMS. Please follow the Problem Reporting Guidelines to find your debug.log and attach it here so I can see what is causing this problem - you'll need to use the instructions near the bottom of that guide to manually find the debug.log file
