Showtime won't play any video
I used UMS when it had the "No Encoding" option in the transcode options on Showtime on my PS3 because thats the only way it'll play any video for me. That option is not there for a while so I had to make things work with codecs. The problem I'm getting when I launch a video that way through Showtime is this:
http://imgur.com/a/Wl0Yr
UMS log shows something like this:
Any ideas?TRACE 2013-11-05 14:59:39.849 [Timer-1] buffered: -9,223,372,034,471,884,800 bytes / inputs: 1
TRACE 2013-11-05 14:59:41.849 [Timer-1] buffered: -9,223,372,034,458,511,360 bytes / inputs: 1
TRACE 2013-11-05 14:59:42.080 [New I/O worker #8] Resume Read: readCount=9223372034707234816 / writeCount=250120192
TRACE 2013-11-05 14:59:42.080 [New I/O worker #8] Suspend Read: readCount=9223372034707243007 / writeCount=250120192
TRACE 2013-11-05 14:59:43.850 [Timer-1] buffered: -9,223,372,034,443,448,319 bytes / inputs: 1
TRACE 2013-11-05 14:59:45.850 [Timer-1] buffered: -9,223,372,034,431,608,831 bytes / inputs: 1
TRACE 2013-11-05 14:59:47.850 [Timer-1] buffered: -9,223,372,034,420,226,047 bytes / inputs: 1
TRACE 2013-11-05 14:59:49.581 [New I/O worker #8] Resume Read: readCount=9223372034707243007 / writeCount=299022336
TRACE 2013-11-05 14:59:49.581 [New I/O worker #8] Suspend Read: readCount=9223372034707243008 / writeCount=299022336
TRACE 2013-11-05 14:59:49.850 [Timer-1] buffered: -9,223,372,034,406,354,944 bytes / inputs: 1
TRACE 2013-11-05 14:59:51.850 [Timer-1] buffered: -9,223,372,034,392,209,408 bytes / inputs: 1
TRACE 2013-11-05 14:59:53.682 [UPNPHelper] Receiving a NOTIFY from [192.168.1.8:61332]
TRACE 2013-11-05 14:59:53.683 [UPNPHelper] Receiving a NOTIFY from [192.168.1.8:61332]
TRACE 2013-11-05 14:59:53.850 [Timer-1] buffered: -9,223,372,034,376,286,208 bytes / inputs: 1
TRACE 2013-11-05 14:59:55.850 [Timer-1] buffered: -9,223,372,034,362,304,512 bytes / inputs: 1
TRACE 2013-11-05 14:59:57.081 [New I/O worker #8] Resume Read: readCount=9223372034707243008 / writeCount=354207744
TRACE 2013-11-05 14:59:57.081 [New I/O worker #8] Suspend Read: readCount=9223372034707251199 / writeCount=354207744
TRACE 2013-11-05 14:59:57.850 [Timer-1] buffered: -9,223,372,034,346,803,199 bytes / inputs: 1
TRACE 2013-11-05 14:59:59.850 [Timer-1] buffered: -9,223,372,034,334,066,687 bytes / inputs: 1
TRACE 2013-11-05 15:00:01.851 [Timer-1] buffered: -9,223,372,034,319,990,783 bytes / inputs: 1
TRACE 2013-11-05 15:00:03.851 [Timer-1] buffered: -9,223,372,034,302,853,119 bytes / inputs: 1
TRACE 2013-11-05 15:00:04.582 [New I/O worker #8] Resume Read: readCount=9223372034707251199 / writeCount=409397248
TRACE 2013-11-05 15:00:04.582 [New I/O worker #8] Suspend Read: readCount=9223372034707251200 / writeCount=409397248
TRACE 2013-11-05 15:00:05.851 [Timer-1] buffered: -9,223,372,034,286,792,704 bytes / inputs: 1
TRACE 2013-11-05 15:00:07.851 [Timer-1] buffered: -9,223,372,034,269,063,168 bytes / inputs: 1
TRACE 2013-11-05 15:00:08.687 [UPNPHelper] Receiving a NOTIFY from [192.168.1.8:61331]
TRACE 2013-11-05 15:00:08.688 [UPNPHelper] Receiving a NOTIFY from [192.168.1.8:61331]
TRACE 2013-11-05 15:00:08.689 [UPNPHelper] Receiving a NOTIFY from [192.168.1.8:61331]
TRACE 2013-11-05 15:00:09.851 [Timer-1] buffered: -9,223,372,034,254,307,328 bytes / inputs: 1
TRACE 2013-11-05 15:00:11.851 [Timer-1] buffered: -9,223,372,034,238,558,208 bytes / inputs: 1
TRACE 2013-11-05 15:00:12.082 [New I/O worker #8] Resume Read: readCount=9223372034707251200 / writeCount=470519808
TRACE 2013-11-05 15:00:12.082 [New I/O worker #8] Suspend Read: readCount=9223372034707259391 / writeCount=470519808
TRACE 2013-11-05 15:00:13.851 [Timer-1] buffered: -9,223,372,034,223,433,727 bytes / inputs: 1
DEBUG 2013-11-05 15:00:15.135 [AWT-EventQueue-0] Checking dbgpack property in UMS.conf
DEBUG 2013-11-05 15:00:15.135 [AWT-EventQueue-0] adding C:\Program Files (x86)\Universal Media Server\renderers\WMP.conf
DEBUG 2013-11-05 15:00:15.136 [AWT-EventQueue-0] adding C:\Program Files (x86)\Universal Media Server\renderers\Showtime4.conf
DEBUG 2013-11-05 15:00:15.136 [AWT-EventQueue-0] adding C:\ProgramData\UMS\WEB.conf
DEBUG 2013-11-05 15:00:15.136 [AWT-EventQueue-0] adding C:\ProgramData\UMS\UMS.conf
DEBUG 2013-11-05 15:00:15.136 [AWT-EventQueue-0] adding C:\ProgramData\UMS\debug.log.prev
TRACE 2013-11-05 15:00:15.851 [Timer-1] buffered: -9,223,372,034,208,241,663 bytes / inputs: 1
TRACE 2013-11-05 15:00:17.851 [Timer-1] buffered: -9,223,372,034,190,534,655 bytes / inputs: 1
TRACE 2013-11-05 15:00:19.583 [New I/O worker #8] Resume Read: readCount=9223372034707259391 / writeCount=529803264
TRACE 2013-11-05 15:00:19.583 [New I/O worker #8] Suspend Read: readCount=9223372034707259392 / writeCount=529803264
TRACE 2013-11-05 15:00:19.852 [Timer-1] buffered: -9,223,372,034,176,503,808 bytes / inputs: 1
TRACE 2013-11-05 15:00:21.852 [Timer-1] buffered: -9,223,372,034,167,382,016 bytes / inputs: 1
TRACE 2013-11-05 15:00:23.689 [UPNPHelper] Receiving a NOTIFY from [192.168.1.8:61330]
TRACE 2013-11-05 15:00:23.690 [UPNPHelper] Receiving a NOTIFY from [192.168.1.8:61330]
TRACE 2013-11-05 15:00:23.691 [UPNPHelper] Receiving a NOTIFY from [192.168.1.8:61330]
- (37.09 KiB) Downloaded 344 times
Re: Showtime won't play any video
Hi WildEast, it would be cool if you can let me know when the "No Encoding" option disappeared
