UMS 7.6 won´t start under 2012R2
Andy1965
Post by Andy1965 »
after install java 191x64 und update to 7.6 ums won´t start.
Full deinstall, delete all ums and java dir´s and reinstall won´t help.
ums end without error, event log oder any other log ...
thanks for help
Andy1965
Re: UMS 7.6 won´t start under 2012R2
Post by Andy1965 »
Switch back to 7.5 and UMS run´s well ...
there are any problems with 2012R2 oder other server versions with ums 7.6?
Hi Andy, the logs are usually saved in the ProgramData directory, can you please check there? Usually something like C:/ProgramData/UMS/debug.log
Andy1965
Post by Andy1965 »
the failure continue with,
UMS 7.9.0 and 8.0.0 RC1 with
java 8U191
and NO logfile exist!
it seems that other user have the same problem.
thanks for help
