Can't use external subs if the files has interal ones already. Can't use FFMPEG for subtitles.
youngoliverreed
Post by youngoliverreed »
I am currently using UMS 7.5.0 on a PS3.
For some reason whenever I change version of UMS I get a bunch of problems but with 7.5.0 these seems to be the only ones so I'd rather not change version.
As the titles says, if a file has internal subtitles then I can't see the external one in the Transcode folder. I can see that star next to the filename that I think comes with externals subs. filename*
I also can't use FFmpeg for the subtitles(This content cannot be played. 800288E1), I have to use MEncoder. This has not been a problem with other versions of UMS.
Thanks.
