Help with UMS
bassmasta1990
Help with UMS
hello
ok so im very new at trying to do this and i sure you guys get this all the time. but here it goes, i can not get my UMS to connect with my ps3 at all. here is hardware stats
toshiba qausmio windows 7
asus router RT-AC66U (upnp enabled)
PS3 hooked up through wifi (will not be able to do LAN connection)
computer hooked up hard wired.
media sharing enabled on my ps3
if some one has come across this situation before please help me out. also like i said pretty new at this so if you can tell me without completely confusing me, it would be much appreciated lol. thanks
Re: Help with UMS
try to disable your firewall (probably windows firewall), if UMS will be seen by PS3 then its firewall fault and you need to make rule for UMS.
server: C2D E6750@2.66GHz 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
Re: Help with UMS
If you search the forum on "firewall", you will find a few threads where I helped people to punch holes in the firewall so that UMS works with firewall switched on.
Also if you quickly want help, read the rules on how to ask for help; not only you should describe your setup, but you should deliver your configuration file(s) and debug.log.
bassmasta1990
Re: Help with UMS
ok i have tried that and weirdly enough. i cant get my windows firewall to work. my router has a firewall but i enabled media sharing on it.
