PS4 Not Deteccting Any Longer
Re: PS4 Not Deteccting Any Longer
I looked in your log and can't see any signs of any communication from other devices. Since you have tested with the firewall off, there must be something with your network. It seems that UMS binds to a Wifi NIC using 192.168.11.0/24. I don't know if that is correct or not, but you should made sure that your PS4 has an IP address in the same subnet (that means, starting with 192.168.11).
UPnP/DLNA only works within the subnet, and aren't in practice "routable" (although there exists ways to configure routing but this is an advanced topic way beyond the scope of this support forum).
If your PS4 is indeed on the same subnet, you should try to cold restart (physically remove power for 5-10 seconds) your router. I have seen a few cases where routers has stopped passing on multicast messages due to some internal bug that is "magically" fixed once rebooted.
