Download automatic subtitles? (LiveSubtitles?)
Re: Download automatic subtitles? (LiveSubtitles?)
It's the one called "Live subtitles", enable it and then browse to the "Live subtitles" folder to query opensubtitles for suggestions. You will usually get multiple suggestions back, the are listed in descending "match score" according to your language preferences.
The opensubtitles server is often over-loaded so it doesn't always "work". Also, if you make too many requests in a limited periode of time, opensubtitles might temporarily "ban" your IP for a while. It is possible, if you have an opensubtitles VIP account, to enter your account details in the UMS credentials, which will let you use these credentials when contacting opensubtitles, which will forward you to the "VIP server" which won't suffer from overloading or rate limits.
