Is there any way to get audio only transcoding?
Re: Is there any way to get audio only transcoding?
I tried your configuration on a Panasonic TX-50GX810E and it works well. Have you found a way to enable subtitles too?
For streaming without transcoding, any idea upon the minimum network speed to be able to stream without issues?
Regards,
Cristian.
Regards,
Cristian.
There are no such limit, it all depends on the media file. They have a wild variety of bitrate requirements, to stream really high quality content you'd need 1Gbps wired or 802.11ac wireless or better.
