[Solved] is there a way to use FFMPEG options
I was hoping to be able to use the pcm_s16be ffmpeg option. I was wondering if there was a way to set this up in the renderer's conf file or anywhere for that matter. Thanks!
Re: is there a way to use FFMPEG options
it appears that this worked in the renderer conf file:
CustomFFmpegOptions= -acodec pcm_s16be
