Profile for Samsung UA60H7000
Hi I have a Samsung UA60H7000 and am wondering what profile to use best for this.
When I let UMS decide it falls back to Samsung-NotCD.conf but then some videos will not play. If I force it to use Samsung LED UHD it uses profile Samsung-UHD.conf.
While this works I do get a prompt on the TC that says "This may not play properly" but so far it does. So question is what other profile should I use that provides better compatibility?
Thank you.
Thank you.
