Upgrade 9.3 - Windows current upgrades - UMS doesn't start anymore
Ctx : Windows 10 Pro.
During the last two year each time I receive an upgrade I validation and installed it without the "clean" option.
I got back my configuration and connexions without problem.
This last time (03/07/2020 v 9.3), this happens :
- I thought to run again install but in clean mode, but how to get back the configurations after if this solves the start problem ?
Best regards
Trebly
- the upgrade stopped on the jre-x64 : unable to upgrade "error opening file to upgrade" (I renamed the jre current directory to old)
- After the end of installation the loading panel is displayed but remains which means that it doesn't start any process from the exe (just shows the logo and hangs).
Best regards
Trebly
Re: Upgrade 9.3 - Windows current upgrades - UMS doesn't start anymore
Checked debug.log.
Found error in "Database connection error : IO Exception : null
Look at new thread with this simple subject.
Trebly
Checked debug.log.
Trebly
It probably means you tried to install the program while it was still running. Please restart the computer and try installing again.
If that still doesn't work, try opening Task Manager (right-click an empty part of the taskbar and click Task Manager) and then close "javaw.exe"
Thanks, I have done all of this, but I don't got any solution.
Looking into ums.log I found that that crash was coming from a failure at opening the database.
After this I have created a new thread with a new title, this to formulate the problem in an other manner, report the tests that I have done.
https://www.universalmediaserver.com/fo ... 035#p41035
