HOWTO - UMS - Render Select Window
This is for if you know for sure you only need certain renderer(s) in your UMS configuration.
By clicking on this Button in the "General Configuration" Tab you can enable All, Disable all, or enable the ones you want.
In the example above, i only want to have DirecTV HR, Playstation 3, Samsung AllShare, Samsung Mobile, and Xbox 360 enabled.
The rest UMS will ignore on load.
Once you have your Renderers selected, you will have to "Save" and "Quit" UMS and reload it for the settings to take effect.
Please keep in mind that the names shown here are reflected to the "RendererName=" section in the CONF file:
e.g.
e.g.
RendererName=Samsung MobilePlease remember to Upload your debug logs!
Universal Media Server Wiki!
