Subtitle missing for 43RU7102 Samsung
dusabogdan
Hey guys,
I just bought 2 new tvs in my home, the model is Samsung 43RU7102.
I have Windows 10 PRO with latest update , and Universal Media Server is also the latest 9.4.2. I've been watching for a long time movies streamed trough UMS on my 49MU6202 Samsung and everything is ok. When i tried to play the movies on the newer models , 43RU7102 , the movies are playing but the subtitle (romanian subtitle ) isn't available anywhere, neither in Subtitle option while playing the movie, neither in Transcode folder. Is this a bug on this version of UMS? I just checked the MU6202 uses Samsung-UHD.conf and the other models uses Samsung-UHD-2019.conf ... Can this be the issue? Thanks a lot...
dusabogdan
Re: Subtitle missing for 43RU7102 Samsung
So... nobody knows anything?
You didn't give any information... read the text in red above.
dusabogdan
The trace files don't help you with this problem.... it's very simple actually... they can check the difference between UHD and UHD 2019 configuration files... and there is the problem... uhhh, i did'nt know that's why i don't get an answer regarding this. Sweet customer help and support !
Are you aiming for the "How not to get help from others on a forum" of the year award or something?
Who's the customer, and who's the seller? I'm certainly neither. If you were tricked into buying UMS, you should contact your local police since you've probably been scammed. UMS is free and open source, and everything is done by volunteers like you and me. The same goes for this forum.
I don't know about you, but I sure can't tell what the reason you don't get subtitles by comparing renderer configuration files. If you know the reason and have identified it to the renderer configuraiton file, why don't you just edit the file?
I was simply trying to give you a hint as to why you didn't get any replies. You gave no useful information to anybody, so there's nothing anybody can reply except for asking you to supply information. Since that's already stated clearly on the top of the page, I guess most don't see the need to explicitly tell you. I did though, because it seemed to me that you didn't understand it.
I can't speak for anybody else, but I can only state that with the information you have given (which is as good as nothing), I can't even begin to guess what the reason for your problem might be. I suspect that the same is true for most others.
dusabogdan
Here is the debug file.
- (84.53 KiB) Downloaded 375 times
dusabogdan
From what i saw when i was comparing them, the UHD 2019 conf file not have SUBRIP as much as in UHD simple...
From what I can see, the configuration is correct. It looks to me like there one or more bugs in UMS's subtitle handling. I know it was changed in one of the 9.x versions, so I would try an earlier version of UMS.
Here is the "decision process", and it doesn't make sense to me at least:
In addition to the above, I've verified that UMS never actually offers the subtitles to the renderer, and it is thus never transferred.
TRACE 2020-04-30 19:44:11.022 [HTTPv2 Request Worker 11] net.pms.formats.Format Parsing results for file "Sleepy.Video.mkv": Container: MKV, Size: 6261993304, Overall Bitrate: 5463779, Video Tracks: 1, Video Codec: h264, Duration: 2:32:48.736, Video Resolution: 1920 x 1080, Display Aspect Ratio: 16:9, Scan Type: Progressive, Frame Rate: 23.976, Frame Rate Mode: CFR (CFR), Frame Rate Mode Raw: CFR, Matrix Coefficients: BT.709, Reference Frame Count: 2, AVC Level: 4, AVC Profile: high, Audio Tracks: 1 [Id: 0, Language Code: eng, Audio Track Title From Metadata: English, Audio Codec: AC3, Bitrate: 384000, Channels: 6, Sample Frequency: 48000 Hz], Subtitle Tracks: 1 [Embedded, id: 0, type: SUBRIP, lang: eng], Mime Type: video/x-matroska
DEBUG 2020-04-30 19:44:11.042 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAMediaSubtitle Set detected charset "ISO-8859-2" and language "ro" for D:\D\X\folder\Sleepy.Video.srt
TRACE 2020-04-30 19:44:11.049 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource Adding new child "Sleepy.Video.mkv" with class "RealFile"
TRACE 2020-04-30 19:44:11.050 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource Looking for an audio track with language "eng" for "Sleepy.Video.mkv"
TRACE 2020-04-30 19:44:11.050 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource Matched audio track: Id: 0, Language Code: eng, Audio Track Title From Metadata: English, Audio Codec: AC3, Bitrate: 384000, Channels: 6, Sample Frequency: 48000 Hz
TRACE 2020-04-30 19:44:11.050 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource Searching for a match for audio language "eng" with audio "eng" and subtitles "off" for "Sleepy.Video.mkv"
DEBUG 2020-04-30 19:44:11.050 [HTTPv2 Request Worker 11] net.pms.configuration.ConfigurationReader Reading subtitles_languages: "ro,rum,eng,fre,jpn,ger,und" (default: "eng,fre,jpn,ger,und")
TRACE 2020-04-30 19:44:11.050 [HTTPv2 Request Worker 11] net.pms.util.SubtitleUtils Looking for subtitles with the highest priority from ro, rum, eng, fre, jpn, ger, und
TRACE 2020-04-30 19:44:11.051 [HTTPv2 Request Worker 11] net.pms.util.SubtitleUtils Returning subtitles with priority External, type: SUBRIP, lang: ro, externalFile: D:\D\X\folder\Sleepy.Video.srt, external file character set: ISO-8859-2: {}
TRACE 2020-04-30 19:44:11.051 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource Ignoring the "off" language because external subtitles are enforced, returning: External, type: SUBRIP, lang: ro, externalFile: D:\D\X\folder\Sleepy.Video.srt, external file character set: ISO-8859-2 for "Sleepy.Video.mkv"
TRACE 2020-04-30 19:44:11.051 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource This video has external subtitles that must be transcoded
TRACE 2020-04-30 19:44:11.051 [HTTPv2 Request Worker 11] net.pms.formats.FormatFactory Getting player for resource "Sleepy.Video.mkv"
TRACE 2020-04-30 19:44:11.051 [HTTPv2 Request Worker 11] net.pms.formats.FormatFactory Returning compatible player "FFmpeg Video"
TRACE 2020-04-30 19:44:11.052 [HTTPv2 Request Worker 11] net.pms.configuration.FormatConfiguration Matched support line f:mkv v:h264 a:ac3|lpcm|adpcm|aac-lc|he-aac|wma|eac3|mp3 m:video/x-matroska w:4096 h:2160 b:600000000 se:ASS|MICRODVD|SAMI|SUBRIP|TEXT|TX3G si:ASS|SUBRIP|VOBSUB
DEBUG 2020-04-30 19:44:11.052 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource Final verdict: "Sleepy.Video.mkv" will be streamed
TRACE 2020-04-30 19:44:11.052 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource File "Sleepy.Video.mkv" will be sent with MIME type "video/x-matroska"
TRACE 2020-04-30 19:44:11.053 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource Adding "Sleepy.Video.mkv" to transcode folder for player: "null"
TRACE 2020-04-30 19:44:11.053 [HTTPv2 Request Worker 11] net.pms.formats.FormatFactory Matched format SubRip to "D:\D\X\folder\Sleepy.Video.srt"
TRACE 2020-04-30 19:44:11.055 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource End of analysis for D:\D\X\Sleepy.Video
TRACE 2020-04-30 19:44:11.056 [HTTPv2 Request Worker 12] net.pms.dlna.DLNAResource discover 33 refresh forced: true
TRACE 2020-04-30 19:44:11.056 [HTTPv2 Request Worker 11] net.pms.dlna.DLNAResource Subtitles "Sleepy.Video.srt" aren't valid for streaming to [TV] Samsung 7 Series (43)
TRACE 2020-04-30 19:44:11.057 [HTTPv2 Request Worker 12] net.pms.dlna.DLNAResource End of analysis for D:\D\X\Sleepy.Video
TRACE 2020-04-30 19:44:11.058 [HTTPv2 Request Worker 12] net.pms.dlna.DLNAResource Subtitles "Sleepy.Video.srt" aren't valid for streaming to [TV] Samsung 7 Series (43)
dusabogdan
Ok, so you say i should try a version older than 9.0.0 ? Thanks
Yes, I'm not exactly sure when what changes happened, so I would go back enough "to be sure".
