Samsung UE55ES6340 fast foward/back/remaining time issues
tkalfaoglu
Post by tkalfaoglu »
Hello.. When playing most videos, the samsung tv (UE55ES6340) cannot 'tell' the length of the movies (always shows 00:00:00) and fast forward / back buttons do not work.
I am guessing this is due to the transcoding that the UMS does.. The UMS is running on Fedora 32 Linux btw.
Is there a way to enable forward/back to work?
Many thanks,
Turgut Kalfaoglu
tkalfaoglu
Re: Samsung UE55ES6340 fast foward/back/remaining time issues
Update: I found this in the logs:
This is server 9.4.2 btw..
INFO 17:06:37.743 [main] Universal Media Server is now available for renderers to find
ERROR 17:06:57.386 [UPNP-[TV]bizimtv] Failed to send action "GetPositionInfo" to [TV]bizimtv: Error: Current state of service prevents invoking that action. Non-recoverable remote execution failure: 400 Bad Request. (HTTP response was: 400 Bad Request)
INFO 17:07:41.097 [HTTPv2 Request Worker 5] Media renderer was not recognized. Possible identifying HTTP headers:
User-Agent: DAFUPnP
Cache-Control: no-cache
Pragma: no-cache
ERROR 19:07:34.739 [UPNP-[TV]bizimtv] Failed to send action "GetPositionInfo" to [TV]bizimtv: Error: Current state of service prevents invoking that action. Non-recoverable remote execution failure: 400 Bad Request. (HTTP response was: 400 Bad Request)
tkalfaoglu
Furthermore, the playback stops about 4 minutes BEFORE the movie ends. the TV gives a "Network Error"..
I assume the ffmpeg runs out of streams and when it returns, the UMS stops sending before sending out the entire 400MB of buffer - I had it set for 400MB.
It seems like this is a limitation of that TV. Does it work with any other media servers? If so we could use that to learn how
