Correct configuration for Samsung NU6900 Series - 2160p - Smart - 4K UHD TV
Hi guys,
I have a Samsung NU6900 Series - 2160p - Smart - 4K UHD TV. It is the primary rendering device being used by UMS. What is the correct configuration information required by UMS for this device? I'm currently experiencing a lot of buffering issues and it does not seem to be localized to any specific files. A WIFI connection is currently being used. An ethernet wired connection is not currently possible because my modem is located upstairs and the TV is located down stairs. I live in an apartment so running cable isn't possible/feasible. UMS is being hosted on a Windows 10 PC. The PC is a custom build Ryzen 7 2700X. Eight cores 16 threads, 32 GB of memory so processing power should not be an issue. Any thoughts you have are welcome.
