as per ANOTHER suggestion... 3.2.0 and issues. again.
Monica Jae
Getting connection to server failed...
This is all out of box; clean install.
- (73.08 KiB) Downloaded 558 times
Monica Jae
Re: as per ANOTHER suggestion... 3.2.0 and issues. again.
also, there are two instances of Universal Media Server on my TV, and there are two instances of Java platform Binary in task manager, which is using up over 600MB of memory. Why? One question i have is, "Since java is such a memory and resource hog, why use it? like seriously? Why not C# or ajax?" Why does anyone use java at all anymore? it's like Minecraft all over again. Unles you use "this" gpu or "this" os or have more than "this" amount of memory, your system will fail. That's why it's virtually flawless on xbox 360 is because it isn't a java platform game. I digress...
i bring this up because i noticed also with older versions, that UMS will start to "act up" after a while. video starts to skip or lag or stop all together. it's doing that now. oh, and it is working, unless you haven't surmised this by now; but not without it's problems
Monica Jae
well, there is a lot of stuttering...i have "reproduced this bug" ... i think.
- (529.94 KiB) Downloaded 496 times
ohh this is an easy fix =)Monica Jae wrote:also, there are two instances of Universal Media Server on my TV, and there are two instances of Java platform Binary in task manager, which is using up over 600MB of memory. Why? One question i have is, "Since java is such a memory and resource hog, why use it? like seriously? Why not C# or ajax?" Why does anyone use java at all anymore? it's like Minecraft all over again. Unles you use "this" gpu or "this" os or have more than "this" amount of memory, your system will fail. That's why it's virtually flawless on xbox 360 is because it isn't a java platform game. I digress...
Kill both instances of java.exe in your task manager...
relaunch UMS -- itll work now.
A lot of things use Java still -- a lot. Its a resource hog only if you have limited resources. My Java.exe never goes above 300 mb, which is pennies compared to my 24 GB of ram.
just curious but what kind of system do you have?
Universal Media Server Wiki!
Thats a hell of a debug file.. 25mb... might take a few to look though it -- subjunk will find it right away... watch.. .Monica Jae wrote:well, there is a lot of stuttering...i have "reproduced this bug" ... i think.
Is it possible to restart UMS, change log to TRACE, reproduce problem and make a log? In 25MB file it is almost impossible to search for anything.
Monica Jae
wow that is big lol how did that happen ??!!
ok, brb
ok, brb
Monica Jae
system? = win 8.1 pro 64bit WMC/8gb/i5 vpro/fujitsu t732/ intel hd 4000/1tb hdd/...DeFlanko wrote:ohh this is an easy fix =)Monica Jae wrote:also, there are two instances of Universal Media Server on my TV, and there are two instances of Java platform Binary in task manager, which is using up over 600MB of memory. Why? One question i have is, "Since java is such a memory and resource hog, why use it? like seriously? Why not C# or ajax?" Why does anyone use java at all anymore? it's like Minecraft all over again. Unles you use "this" gpu or "this" os or have more than "this" amount of memory, your system will fail. That's why it's virtually flawless on xbox 360 is because it isn't a java platform game. I digress...
Monica Jae
ok, here it is. now THAT's more reasonable lol
Just trying to think outside of the box for a minute here -- and because i don't have a windows 8 machine yet... I'm going to "shoot in the dark for a minute" here.
1) Did you happen to update to Windows 8 SP1 yet? (its a free update)
2) Do you have file extensions turned on in windows?
I know in windows 7 its under here:
then:
Only reason why i ask is it looks like some files in discovery, the file extensions are not being seen (or they are and thats how you have them..)
or
and maybe because the ones that are labeled as such are not really mp4's btu thats how UMS reads them because of the name.:
Also do you use Virtual folders?
_____If so, what happens when you don't virtual folder the same file locations?
then:
TRACE 2013-12-05 10:50:29.448 [New I/O worker #7] Could not match any format to "E:\My Stuff\TV\Person.of.Interest.S02.Season.2.720p.HDTV.x264-PublicHD"Code: Select all
TRACE 2013-12-05 10:50:29.439 [New I/O worker #7] tsMuxeR cannot determine compatibility based on audio track for E:\My Stuff\TV\Futurama.Season.7.Complete.720p.WEB-DL.x264.AACCode: Select all
TRACE 2013-12-05 10:50:29.474 [New I/O worker #7] Matched format MPG to "E:\My Stuff\TV\Person.of.Interest.S03E03.HDTV.x264-LOL.mp4"
TRACE 2013-12-05 10:50:29.513 [New I/O worker #7] Parsing results for file "Person.of.Interest.S03E03.HDTV.x264-LOL.mp4": container: mp4, bitrate: 797362, size: 260165289, video codec: h264, duration: 00:43:30.00, width: 720, height: 404, frame rate: 23.976, muxing mode: null, mime type: video/mp4
Audio track id: 0, lang: und, flavor: null, audio codec: AAC, sample frequency:48000, number of channels: 2, bits per sample: 16
TRACE 2013-12-05 10:50:29.513 [New I/O worker #7] Adding new child "Person.of.Interest.S03E03.HDTV.x264-LOL.mp4" with class "net.pms.dlna.RealFile"
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:mpegps|mpegts v:mpeg1|mpeg2|mp4|h264 a:ac3|lpcm|aac|mpa m:video/mpeg
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:avi|divx v:mp4|divx|mjpeg a:mp3|lpcm|mpa|ac3 m:video/divx qpel:yes|no gmc:0
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:wmv v:wmv|vc1 a:wma m:video/x-ms-wmv n:2
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:wav m:audio/wav n:6 a:dts|lpcm s:48000
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:wav m:audio/wav n:2 s:48000
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:mp3 m:audio/mpeg n:2
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:aac m:audio/x-m4a n:2 a:(?!alac).+
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:wma m:audio/x-ms-wma n:2
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:atrac m:audio/x-oma n:2
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:jpg m:image/jpeg
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:png m:image/png
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:gif m:image/gif
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Format "mp4" failed to match supported line f:tiff m:image/tiff
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] File "Person.of.Interest.S03E03.HDTV.x264-LOL.mp4" can be transcoded
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Getting player for resource "Person.of.Interest.S03E03.HDTV.x264-LOL.mp4"
TRACE 2013-12-05 10:50:29.514 [New I/O worker #7] Returning compatible player "MEncoder"
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:wmv v:wmv|vc1 a:wma m:video/x-ms-wmv n:2
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:wav m:audio/wav n:6 a:dts|lpcm s:48000
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:wav m:audio/wav n:2 s:48000
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:mp3 m:audio/mpeg n:2
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:aac m:audio/x-m4a n:2 a:(?!alac).+
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:wma m:audio/x-ms-wma n:2
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:atrac m:audio/x-oma n:2
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:jpg m:image/jpeg
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:png m:image/png
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:gif m:image/gif
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Format "mp4" failed to match supported line f:tiff m:image/tiff
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] File "Person.of.Interest.S03E03.HDTV.x264-LOL.mp4" is not supported by the renderer
TRACE 2013-12-05 10:50:29.515 [New I/O worker #7] Final verdict: "Person.of.Interest.S03E03.HDTV.x264-LOL.mp4" will be transcoded with player "MEncoder" with mime type "video/mp4"
