Fix for no subtitles on Samsung TV (RU7xxx 2019 Series)
Hi
I had many problems with subs on my Samsung 58RU7102 - they don't work...
I've checked on UMS what config my tv use (click on tv in UMS) - "Samsung-UHD-2019.conf"
Everything what you need to do is:
Open Notepad as administrator
Open File : Samsung-UHD-2019.conf (DIRECTORY: Program Files (x86)\Universal Media Server\renderers)
ADD THESE LINES
Now everything should works like a charm
ADD THESE LINES
SupportedExternalSubtitlesFormats = MICRODVD,SAMI,SUBRIP,TEXT
SupportedInternalSubtitlesFormats = ASS,DIVX,SUBRIP,VOBSUB
Re: Fix for no subtitles on Samsung TV (RU7xxx 2019 Series)
Thanks for sharing this. It is needed because of a bug that will be fixed in the next release, so you shouldn't need to make this change anymore after 9.5.1+
Here is a pre-release fix for you to try if you want https://www.universalmediaserver.com/up ... 013eda.exe
