Server starts OK, but no GUI
ums_no_gui
When I run the script or the jar on linux, no GUI appears. The server appears to start and bind to a port OK, just no GUI. I see a blurry icon appear in the system tray, but clicking it does nothing, and there is no context menu for it either. PS3 Media Server works OK though.
I tried searching for this on the forums, but the search functionality unhelpfully filters the words "no" "doesn't" "start" etc.
Log file:
DEBUG 2013-12-07 16:52:41.652 [main] Reading cred.path: default: "", current: "/home/will/.config/UMS/UMS.cred"
DEBUG 2013-12-07 16:52:41.657 [main] Reading run_wizard: default: true, current: false
INFO 2013-12-07 16:52:41.657 [main] Starting Universal Media Server 3.2.0
INFO 2013-12-07 16:52:41.658 [main] Based on PS3 Media Server by shagrath, copyright 2008-2013
INFO 2013-12-07 16:52:41.658 [main] http://www.universalmediaserver.com
INFO 2013-12-07 16:52:41.658 [main] Build: 735d481a2 (2013-12-01)
INFO 2013-12-07 16:52:41.658 [main] Java: OpenJDK 64-Bit Server VM 1.7.0_25 64-bit by Oracle Corporation
INFO 2013-12-07 16:52:41.658 [main] OS: Linux 64-bit 3.11.0-14-generic
INFO 2013-12-07 16:52:41.658 [main] Encoding: UTF-8
INFO 2013-12-07 16:52:41.664 [main] Memory: 682 MB
INFO 2013-12-07 16:52:41.665 [main] Language: en
INFO 2013-12-07 16:52:41.665 [main] Working directory: /home/will/ums-3.2.0
INFO 2013-12-07 16:52:41.665 [main] Temp directory: /tmp/universalmediaserver
INFO 2013-12-07 16:52:41.666 [main] Logging config file: /home/will/ums-3.2.0/logback.xml
INFO 2013-12-07 16:52:41.666 [main] debug.log: /home/will/.config/UMS/debug.log
INFO 2013-12-07 16:52:41.666 [main] Profile directory: /home/will/.config/UMS
INFO 2013-12-07 16:52:41.666 [main] Profile directory permissions: rw
INFO 2013-12-07 16:52:41.667 [main] Profile path: /home/will/.config/UMS/UMS.conf
INFO 2013-12-07 16:52:41.667 [main] Profile permissions: rw
INFO 2013-12-07 16:52:41.667 [main] Profile name: willbuntu
INFO 2013-12-07 16:52:41.667 [main] Web conf path: /home/will/.config/UMS/WEB.conf
INFO 2013-12-07 16:52:41.667 [main] Web conf permissions: file not found
DEBUG 2013-12-07 16:52:41.928 [main] Reading minimized: default: false, current: true
DEBUG 2013-12-07 16:52:41.939 [main] Reading hide_advanced_options: default: true, current: false
DEBUG 2013-12-07 16:52:41.953 [main] Reading maximum_bitrate: default: "110", current: "50"
DEBUG 2013-12-07 16:52:44.543 [main] Reading mpeg2_main_settings: default: "Automatic (Wired)", current: "Automatic (Wireless)"
INFO 2013-12-07 16:52:44.823 [main] Loading MediaInfo library
INFO 2013-12-07 16:52:44.861 [main] Loaded MediaInfoLib - v0.7.64
INFO 2013-12-07 16:52:44.864 [main] Loading renderer configurations from /home/will/ums-3.2.0/renderers
INFO 2013-12-07 16:52:44.870 [main] Loaded configuration for renderer: AirPlayer
INFO 2013-12-07 16:52:44.873 [main] Loaded configuration for renderer: Android
INFO 2013-12-07 16:52:44.877 [main] Loaded configuration for renderer: KalemSoft Media Player
INFO 2013-12-07 16:52:44.880 [main] Loaded configuration for renderer: Sony Bravia 4500
INFO 2013-12-07 16:52:44.884 [main] Loaded configuration for renderer: Sony Bravia 5500
INFO 2013-12-07 16:52:44.888 [main] Loaded configuration for renderer: Sony Bravia EX
INFO 2013-12-07 16:52:44.892 [main] Loaded configuration for renderer: Sony Bravia EX620
INFO 2013-12-07 16:52:44.897 [main] Loaded configuration for renderer: Sony Bravia HX
INFO 2013-12-07 16:52:44.904 [main] Loaded configuration for renderer: Sony Bravia W6/W8/W9
INFO 2013-12-07 16:52:44.907 [main] Loaded configuration for renderer: D-Link DSM-510
INFO 2013-12-07 16:52:44.909 [main] Loaded configuration for renderer: DirecTV HR
INFO 2013-12-07 16:52:44.910 [main] Loaded configuration for renderer: Freebox HD
INFO 2013-12-07 16:52:44.912 [main] Loaded configuration for renderer: Freecom MusicPal
INFO 2013-12-07 16:52:44.913 [main] Loaded configuration for renderer: Pioneer Kuro
INFO 2013-12-07 16:52:44.916 [main] Loaded configuration for renderer: LG 42LA644V
INFO 2013-12-07 16:52:44.919 [main] Loaded configuration for renderer: LG Smart TV Upgrader
INFO 2013-12-07 16:52:44.921 [main] Loaded configuration for renderer: Nokia N900
INFO 2013-12-07 16:52:44.924 [main] Loaded configuration for renderer: Netgear NeoTV
INFO 2013-12-07 16:52:44.926 [main] Loaded configuration for renderer: OPPO BDP-83
INFO 2013-12-07 16:52:44.928 [main] Loaded configuration for renderer: OPPO BDP-93
INFO 2013-12-07 16:52:44.929 [main] Loaded configuration for renderer: Onkyo TX-NR717
INFO 2013-12-07 16:52:44.936 [main] Loaded configuration for renderer: PlayStation 3
INFO 2013-12-07 16:52:44.940 [main] Loaded configuration for renderer: Panasonic TV
INFO 2013-12-07 16:52:44.942 [main] Loaded configuration for renderer: Panasonic TX-L32V10E
INFO 2013-12-07 16:52:44.945 [main] Loaded configuration for renderer: Philips Aurea
INFO 2013-12-07 16:52:44.950 [main] Loaded configuration for renderer: Philips TV
INFO 2013-12-07 16:52:44.952 [main] Loaded configuration for renderer: Popcorn Hour
INFO 2013-12-07 16:52:44.953 [main] Loaded configuration for renderer: Realtek
INFO 2013-12-07 16:52:44.955 [main] Loaded configuration for renderer: Sony SMP-N100
INFO 2013-12-07 16:52:44.960 [main] Loaded configuration for renderer: Samsung SMT-G7400
INFO 2013-12-07 16:52:44.961 [main] Loaded configuration for renderer: Samsung D7000
INFO 2013-12-07 16:52:44.963 [main] Loaded configuration for renderer: Samsung AllShare
INFO 2013-12-07 16:52:44.964 [main] Loaded configuration for renderer: Samsung Mobile
INFO 2013-12-07 16:52:44.965 [main] Loaded configuration for renderer: Samsung WiseLink
INFO 2013-12-07 16:52:44.966 [main] Loaded configuration for renderer: Sharp Aquos
INFO 2013-12-07 16:52:44.969 [main] Loaded configuration for renderer: Showtime 3
INFO 2013-12-07 16:52:44.971 [main] Loaded configuration for renderer: Showtime 4
INFO 2013-12-07 16:52:44.973 [main] Loaded configuration for renderer: Sony Blu-ray
INFO 2013-12-07 16:52:44.976 [main] Loaded configuration for renderer: Sony Home Theatre System
INFO 2013-12-07 16:52:44.978 [main] Loaded configuration for renderer: Sony STR-DA5800ES
INFO 2013-12-07 16:52:44.980 [main] Loaded configuration for renderer: Streamium
INFO 2013-12-07 16:52:44.981 [main] Loaded configuration for renderer: Telstra T-Box
INFO 2013-12-07 16:52:44.982 [main] Loaded configuration for renderer: VideoWeb TV
INFO 2013-12-07 16:52:44.984 [main] Loaded configuration for renderer: Vizio Smart TV
INFO 2013-12-07 16:52:44.986 [main] Loaded configuration for renderer: WD TV Live
INFO 2013-12-07 16:52:44.988 [main] Loaded configuration for renderer: WMP
INFO 2013-12-07 16:52:44.989 [main] Loaded configuration for renderer: XBMC
INFO 2013-12-07 16:52:44.991 [main] Loaded configuration for renderer: Xbox 360
INFO 2013-12-07 16:52:44.992 [main] Loaded configuration for renderer: Yamaha RX-A1010
INFO 2013-12-07 16:52:44.993 [main] Loaded configuration for renderer: Yamaha RX-V3900
INFO 2013-12-07 16:52:44.994 [main] Loaded configuration for renderer: Yamaha RX-V671
INFO 2013-12-07 16:52:44.995 [main] Loaded configuration for renderer: iPad / iPhone
INFO 2013-12-07 16:52:44.995 [main] Please wait while we check the MPlayer font cache, this can take a minute or so.
DEBUG 2013-12-07 16:52:44.996 [main] Launching: [mplayer, dummy]
INFO 2013-12-07 16:52:45.023 [main] Finished checking the MPlayer font cache.
INFO 2013-12-07 16:52:45.024 [main] Please wait while we check the FFmpeg font cache, this can take a minute or so.
DEBUG 2013-12-07 16:52:45.033 [main] Launching: [linux/ffmpeg, -y, -f, lavfi, -i, nullsrc=s=720x480:d=1:r=1, -vf, ass=DummyInput.ass, -target, ntsc-dvd, DummyOutput.mpeg]
INFO 2013-12-07 16:52:45.062 [main] Finished checking the FFmpeg font cache.
INFO 2013-12-07 16:52:45.078 [main] Searching for plugins in /home/will/ums-3.2.0/plugins
INFO 2013-12-07 16:52:45.079 [main] No plugins found
INFO 2013-12-07 16:52:45.087 [main] Registering transcoding engine: FFmpeg Audio
INFO 2013-12-07 16:52:45.091 [main] Registering transcoding engine: MEncoder
INFO 2013-12-07 16:52:45.091 [main] Registering transcoding engine: FFmpeg
INFO 2013-12-07 16:52:45.092 [main] Registering transcoding engine: VLC
DEBUG 2013-12-07 16:52:45.094 [main] Error reading ffmpeg web filters: File '/home/will/.config/UMS/ffmpeg.webfilters' does not exist
DEBUG 2013-12-07 16:52:45.101 [main] FFmpeg supported protocols: [cache, concat, crypto, data, ffrtmphttp, file, ftp, gopher, hls, http, httpproxy, mmsh, mmst, pipe, rtmp, rtmpt, rtp, srtp, tcp, udp, unix, mms]
INFO 2013-12-07 16:52:45.101 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2013-12-07 16:52:45.102 [main] Registering transcoding engine: MEncoder Web
INFO 2013-12-07 16:52:45.102 [main] Registering transcoding engine: VLC Web Video
INFO 2013-12-07 16:52:45.103 [main] Registering transcoding engine: tsMuxeR
INFO 2013-12-07 16:52:45.103 [main] Registering transcoding engine: Audio High Fidelity
INFO 2013-12-07 16:52:45.104 [main] Registering transcoding engine: VLC Web Audio (Legacy)
INFO 2013-12-07 16:52:45.105 [main] Registering transcoding engine: VLC Web Video (Legacy)
INFO 2013-12-07 16:52:45.105 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2013-12-07 16:52:45.148 [main] Using address /192.168.1.3 found on network interface: name:eth0 (eth0)
INFO 2013-12-07 16:52:45.150 [main] Created socket: /192.168.1.3:5001
DEBUG 2013-12-07 16:52:45.213 [main] Sending ALIVE...
DEBUG 2013-12-07 16:52:45.215 [main] Reading uuid: default: null, current: "3868b4ac-9322-4a87-94c9-3558383436f5"
INFO 2013-12-07 16:52:45.215 [main] Using the following UUID configured in UMS.conf: 3868b4ac-9322-4a87-94c9-3558383436f5
INFO 2013-12-07 16:52:45.467 [main] The server is now available for renderers to find
INFO 2013-12-07 16:52:45.477 [New I/O worker #1] No IP filter specified, access granted to /192.168.1.9
INFO 2013-12-07 16:52:45.484 [pool-4-thread-1] Checking IP: 192.168.1.9 for WMP
DEBUG 2013-12-07 16:52:45.493 [New I/O worker #1] HTTP User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50
INFO 2013-12-07 16:52:45.695 [pool-4-thread-1] Renderer WMP found on this address: teevee.local (192.168.1.9)
DEBUG 2013-12-07 16:52:45.701 [pool-4-thread-1] Starting ping -c 3 -s 64000 192.168.1.9
DEBUG 2013-12-07 16:52:45.703 [pool-4-thread-1] Unix process ID (ping): 6095
DEBUG 2013-12-07 16:52:45.704 [Thread-10] PING 192.168.1.9 (192.168.1.9) 64000(64028) bytes of data.
DEBUG 2013-12-07 16:52:45.705 [Thread-10] 64008 bytes from 192.168.1.9: icmp_seq=1 ttl=128 time=1.87 ms
DEBUG 2013-12-07 16:52:46.706 [Thread-10] 64008 bytes from 192.168.1.9: icmp_seq=2 ttl=128 time=1.59 ms
INFO 2013-12-07 16:52:47.049 [New I/O worker #5] No IP filter specified, access granted to /192.168.1.4
INFO 2013-12-07 16:52:47.058 [New I/O worker #5] Another renderer like WMP was found!
DEBUG 2013-12-07 16:52:47.060 [New I/O worker #5] HTTP User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50
INFO 2013-12-07 16:52:47.060 [pool-4-thread-2] Checking IP: 192.168.1.4 for WMP
DEBUG 2013-12-07 16:52:47.701 [SpeedStats Failsafe] Stopping Unix process 6095: ping-0
INFO 2013-12-07 16:52:47.704 [pool-4-thread-1] Address /192.168.1.9 has an estimated network speed of: 295 Mb/s
INFO 2013-12-07 16:52:52.164 [pool-4-thread-2] Renderer WMP found on this address: 192.168.1.4
DEBUG 2013-12-07 16:52:52.165 [pool-4-thread-2] Starting ping -c 3 -s 64000 192.168.1.4
DEBUG 2013-12-07 16:52:52.167 [pool-4-thread-2] Unix process ID (ping): 6102
DEBUG 2013-12-07 16:52:52.170 [Thread-13] PING 192.168.1.4 (192.168.1.4) 64000(64028) bytes of data.
DEBUG 2013-12-07 16:52:52.170 [Thread-13] 64008 bytes from 192.168.1.4: icmp_seq=1 ttl=128 time=2.05 ms
DEBUG 2013-12-07 16:52:53.171 [Thread-13] 64008 bytes from 192.168.1.4: icmp_seq=2 ttl=128 time=2.27 ms
DEBUG 2013-12-07 16:52:54.166 [SpeedStats Failsafe] Stopping Unix process 6102: ping-1
INFO 2013-12-07 16:52:54.167 [pool-4-thread-2] Address /192.168.1.4 has an estimated network speed of: 237 Mb/s
DEBUG 2013-12-07 16:52:55.467 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-12-07 16:53:15.468 [UPNP-AliveMessageSender] Sending ALIVE...
Log file:
Re: Server starts OK, but no GUI
not sure but I allways use ums.sh to run headless (but the true is that I dont use X so thats why its headless)
Im like 90% sure that gui should apeard when starting jar.
I see that "Reading run_wizard: default: true, current: false", could you overright this?
You use Oracle java, could you swith to recomended one ? openjava?
server: C2D E6750@2.66GHz 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
