HOWTO - Notepad ++ and UMS Logs.
For a while now i've been using Notepad++ and figure I'd share how I read logs with you.
First thing you want to do is install notepad++ and Click on "Language" then "Define your language..."
Now you're going to take the "NP++ - Logback - UMS.xml" and import it.
After import successful, select the red "X" on User Defined Language.
Before you open the Debug log, go back to Languages and select "Logback - UMS"
Now open your Debug log and you will see pretty colors.
Enjoy
Version 1.0 Logback - UMS XML for Notepad++
Enjoy
Universal Media Server Wiki!
