Can't play h265 file on PS3
when I try to play an h265 encoded mkv file on PS3 I receive "data not supported" message.
I attach logs as indicated in guidelines.
Thanks to all of you
Re: Can't play h265 file on PS3
I've noted that trouble happens only when I try to transcode a file with subtitles SSA with FFmpeg. If I try to transcode a file with audio only, I can see it perfectly. With MEncoder fails in every cases.
I see, this seems to be a bug with the new MEncoder build we had to make for Catalina, because Apple stopped accepting the older version. I see you're on macOS 10.13 so you might still be able to use our old MEncoder, please try https://www.fosshub.com/Universal-Media ... e10.15.dmg
