"Data type is not supported" (800288BF) error on PS3
Re: "Data type is not supported" (800288BF) error on PS3
Hi, welcome
This likely means there is something unusual about the way the avi file was encoded. PS3 supports most variations of AVI but not all. The file is passing our rules for PS3 support so I guess our rules could do with some updating.
I can see your file is:
Format: "AVI" Duration: 0:51:01.959 Overall Bitrate: 2404528 Cover: No
FPS: 29.970
- Video track ID: 0
Format: "MPEG-4 Visual" Profile: "Advanced Simple@L5" CodecID: "XVID" Duration: 0:51:01.959
Bitrate: 2263283 Width: 718 Height: 474 Colorimetry: 4:2:0
Chroma: 4:2:0 PAR: 0.888 DAR: 4:3 DAR Orig: 4:3
Scan Type: Progressive FPS: 29.970 FPS Orig: 29.970 QPel: "No"
GMC: "0" Bit Depth: 8 Delay: 0
- Audio track ID: 1
Format: "MPEG Audio" Version: "Version 1" Profile: "Layer 3" CodecID: "55"
Duration: 0:51:01.865 BitRate Mode: CBR Bitrate: 128000 Channel(s): 2
Samplerate: 44100 Delay: 0 Delay Source: Stream
That looks mostly normal to me - it is common for AVI files to have that XviD and MP3 combination.
One possible issue is that the resolution is not divisible by 4. For best compatibility across devices, resolution should be divisible by 16.
Do you know how to re-encode that to test? If not I could make you a file to try
FPS: 29.970
- Video track ID: 0
- Audio track ID: 1
The PS3 doesn't support MKV, so all you achieved by doing that is that UMS will transcode the file. The goal here, as I understand it, was to identify the properties of the AVI files that doesn't work on the PS3 so that UMS wouldn't try to send them, but transcode instead - but only when actually needed. It would be simple to make UMS transcode all AVI files, but it would be a waste in both efficiency and quality, since most AVI files can be played as-is.
Thanks for letting us know the alternate solution, as Nadahar said that confirms the transcoding is working, but it would be good to get to the bottom of this if you are willing to do some more testing for usyekale2608 wrote: ↑Sat Sep 05, 2020 5:21 am Thank you for the reply!
I don't know how to re-encode the AVI in the way I think you're suggesting, but I did actually find an alternative solution. Since you said "PS3 supports most variations of AVI but not all," I decided to try to multiplex the AVI through MKVToolNix, creating an MKV. The MKV then streamed to the PS3 without a single problem.
I'm attaching the log files of the successful test of the newly-created MKV for your reference. Hopefully this will help with development and/or anyone else having the same issue.
Thank you again for the help and for the countless hours of happiness I've gotten from UMS.
Would you please test the two videos I attached?
Ok so your file is:
FPS: 29.970
- Video track ID: 0
- Audio track ID: 1
Mine is:
Format: "AVI" Duration: 0:00:12.936 Overall Bitrate: 889450 Cover: No
FPS: 25.000
- Video track ID: 0
Format: "MPEG-4 Visual" Profile: "Advanced Simple@L5" CodecID: "XVID" Duration: 0:00:12.920
Bitrate: 753741 Width: 718 Height: 474 Colorimetry: 4:2:0
Chroma: 4:2:0 PAR: 1.000 DAR: 3:2 Scan Type: Progressive
FPS: 25.000 QPel: "No" GMC: "0" Bit Depth: 8
Delay: 0
- Audio track ID: 1, Title: "video-mpeg4-aac"
Duration: 0:00:12.936 BitRate Mode: CBR Bitrate: 128000 Channel(s): 2
Samplerate: 48000 Delay: 0 Delay Source: Stream
There are some differences here:
Frame rate
Audio sample rate
PAR
DAR
Please try the new files in the attached zip file
FPS: 29.970
- Video track ID: 0
- Audio track ID: 1
Mine is:
FPS: 25.000
- Video track ID: 0
Delay: 0
Frame rate
Audio sample rate
PAR
DAR
- KONTROLMASTER
- Contact:
The issue still exist for me and the files can only be played with the help of MENCODER engine through "Transcode" folder, as the safe haven workaround now. As usual if there is something problematic with it.
Which version of UMS? There is a bug in 14.2.0 that will be fixed in the next version. But 14.1.0 should work
