[Solved] Mark viewed episodes
hvlhector
Post by hvlhector »
I Posted in general forum and maybe here is best option:
Hi, anyone has problem with mark viewed episodes in last versions of UMS?
I have configured and it works until last 2 updates, but now it doesnt mark episodes as viewed. I have reinstalled with clean opcion and reconfigured but nothing.
Im doing something wrong?
(Sry for my english)
Re: Mark viewed episodes
I just checked and it is working for me. Can you provide logs please? https://www.universalmediaserver.com/fo ... ?f=9&t=556
hvlhector
Post by hvlhector »
Hi, here are the logs, thanks for reply.
For additional info, i have been using ps3 to view episodes during last 2 years and "mark media" works fine until last 2 months, with new versions of UMS. Maybe is another thing that works wrong, java or something i didnt know.
ums_dbg_2020-09-09-16-52.zip
(1.23 MiB) Downloaded 430 times
hvlhector
Post by hvlhector »
I have been doing several tests:
1) i have installed older version of UMS but same
2) i have installed older versions of java and nothing
3) installed codecs too
4) changed the option of marked to "move to other folder" and does nothing
5) turned off firewall
Idk whats wrong :S
If anyone knows another thing that i can test is welcome
It seems like this is because the shared folder didn't have "Monitor played status of files" enabled on the Shared Content tab. Sorry for the late reply, this got lost in my notifications
