UMS does not appear on my Samsung Q60.
CFSCastro
Post by CFSCastro »
Before UMS was listed on my TV.
I don't know what changed, I don't know if it was because of the new version of MacOS, Big Sur, or if it was because of the new version of UMS.
I have already disabled the firewall but nothing has changed.
I already updated the java.
My experience in configuring UMS is almost nil.
I use 2 network connections.
Cable - external network
Wifi - local network.
ums_dbg_2020-12-27-14-34.zip
(24.77 KiB) Downloaded 309 times
Re: UMS does not appear on my Samsung Q60.
Try checking to see if UMS is using the correct network interface.
I don't know anything about macs but your UMS is using "en1" which I'm assuming is your wired connection to the external network.
If wifi is your local network then that is what UMS should use.
Go to the "network settings (advanced)" section in the general settings tab and select a different interface in the "force networking on interface" dropbox.
CFSCastro
Post by CFSCastro »
mik_s wrote: ↑Mon Dec 28, 2020 6:50 am Try checking to see if UMS is using the correct network interface.
I'm using wifi on en1, which is my internal ip.
