How to Install UMS on an ARMV7 Nas (32 bits) DS216Play
Stonehenge
Hello
almost newbee here on linux matter.
Is there a guide to install UMS on my Synology NAS Not x86 proc so no Docker available. DSM version is DSM 6.2.3-25426 Update 3 (latest available to this day)
Is there a compatible version ? And idealy is there an how to ?
Thanks.
Thanks.
Re: How to Install UMS on an ARMV7 Nas (32 bits) DS216Play
I don't think you'll find a guide. UMS is Java though, so as long as you have a working Java installation, UMS itself should work if you run the "main" JAR file "ums.jar" like this: java -jar ums.jar
The problem is that UMS can't do all that much alone, it relies on a number of other software. These aren't Java, so you'd have to source versions of these that will work for you platform and replace those that come with UMS. Except for that, you should be able to do a "normal" Linux headless installation as far as I can tell.
