Xbox 360 - Only "Songs" work
If you try to browse "Albums", "Artists", or "Genres" on the Xbox 360, it shows a list of all of them but inside that, there are no files listed.
Only "Songs" works.
For example:
Open System Music Player
Select UMS
Default view is "Albums" with all albums listed.
Select an album and there are no songs found.
Change view to "Songs" and all songs are listed.
Only "Songs" works.
For example:
Select UMS
