Mkv files with opus stop playing before end of video
redtux
Post by redtux »
Several videos encoded with h264/libopus in Matroska format stop playing before video is finished.
It varies howmuch is played, the worst being 14 minutes of an hour video.
The videos play fine on network and using minidlna. There is nothing the logs
Any ideas
Re: Mkv files with opus stop playing before end of video
No idea without any logs. see the section in red above.
redtux
Post by redtux »
I seem to have found a solution, at least so far.If I install mediainfo the problem seems to disappear
redtux
Post by redtux »
Unfortunately I spoke too soon.
It seems to be in connection with the fact that mkv files are playable before they have finished transcoding. So with cache enabled the duration when ums first sees the file is reused whilst the file is a lot bigger.
