Unable to read external drive
monsieurdagon
Post by monsieurdagon »
I am on Mac OS Big Sur 11.4 and using UMS 10.6.0
Here are my problems:
When I am using my PS3 I can't see any file on each of my external drives and the error message 800288E1 appears when I try to read a file from my internal drive.
On the other hand I can read the files from my internal drive with my TV Media Center but not those from my external drives.
Can anyone help me please ?
Thanks a lot
(log attached)
ums_dbg_2021-06-20-17-23.zip
(159.54 KiB) Downloaded 227 times
Re: Unable to read external drive
I can see
WARN  2021-06-20 17:21:50.776 [HTTPv1 Request Worker 211] net.pms.dlna.MapFile Can't read files from directory: /Volumes/SAM
WARN  2021-06-20 17:21:53.669 [HTTPv1 Request Worker 220] net.pms.dlna.MapFile Can't read directory: /Volumes/SAM2
which I assume is your external drive. I don't know anything about macs so can't be of any help. Only thing I can think of is it may be a permissions issue but is just a guess. I don't see anything else in the logs that would suggest a problem with UMS though.
monsieurdagon
Thanks for you quick answer. SAM and SAM2 are my external drives indeed. The thing is that it works on my son's Mac which uses OS 10.13.6 High Sierra. I'll check the permissions anyway. Thanks again !
