cant stream from pc to Sony tv
corky
Post by corky »
downloaded UMS .
added my folders and see them correctly on the UMS web.
see UMS on my tv servers list.
but cant open and don't see it on the media player of the tv.
enable shew of this files on win 10, and disabled the need of password.
Re: cant stream from pc to Sony tv
Could you post logs? See the section above in red or the link in my sig.
corky
Post by corky »
mik_s wrote: ↑Mon Oct 25, 2021 11:18 am Could you post logs? See the section above in red or the link in my sig.
apologize but i don't know how to do it
corky
Post by corky »
peppynite wrote: ↑Mon Oct 25, 2021 6:46 pm Hello! Greetings of the day
Please follow these steps to link your PC to Sony TV
Launch the Wi-Fi Direct Mode on TV. ...
On the computer, select Control Panel on Start menu.
Select Network and Internet (Select Category on View by setting if not displayed)
Select Connect to a network.
Select DIRECT-xx-BRAVIA or the SSID which displayed on TV. ...
Select Connect.
i did this instructions.
actually i was connecter on pc wi fi in a different way.
the strange thing is that when i was connected wired i could see UMS server on the tv servers list.
now i can't see it. but i can see the name of my pc.
the other strange thin that happened is after changing this wii fi connection method, another streaming app that i had , which didn't worked smooth, now becomes better.
but steel cant find UMS on my tv
Ignore that post, it was spam
See the section in red above for instructions.
corky
Post by corky »
i did the log instructions?
edit:
i can see now UMS on tv media , also names of the folders i shared.
but when trying to open it says "selected server does not contain media"
ums_dbg_2021-10-26-10-09.zip
(95.07 KiB) Downloaded 205 times
