[Solved] Detected Media Renderers not showing custom renderers
Re: Detected Media Renderers not showing custom renderers
Will need to see trace log files to be of any help. See the section in red above.
I see an error right after renderer detection that could be the cause in V10.19.0 that does not appear in V10.15.0
DEBUG 2022-04-07 19:50:13.959 [HTTPv2 Request Worker 2] net.pms.network.mediaserver.nettyserver.RequestHandlerV2 Caught exception: null
TRACE 2022-04-07 19:50:13.960 [HTTPv2 Request Worker 2] net.pms.network.mediaserver.nettyserver.RequestHandlerV2
	at net.pms.network.mediaserver.UPNPControl.getURL(UPNPControl.java:339)
	at net.pms.network.mediaserver.UPNPControl.getAddress(UPNPControl.java:820)
	at net.pms.configuration.RendererConfiguration.getAddress(RendererConfiguration.java:1565)
	at net.pms.newgui.StatusTab$RendererItem.<init>(StatusTab.java:91)
	at net.pms.newgui.StatusTab.addRenderer(StatusTab.java:388)
	at net.pms.newgui.LooksFrame.addRenderer(LooksFrame.java:791)
	at net.pms.PMS.setRendererFound(PMS.java:202)
	at net.pms.configuration.RendererConfiguration.resolve(RendererConfiguration.java:687)
	at net.pms.configuration.RendererConfiguration.getRendererConfigurationByHeaders(RendererConfiguration.java:594)
	at net.pms.configuration.RendererConfiguration.getRendererConfigurationByHeaders(RendererConfiguration.java:586)
	at net.pms.network.mediaserver.nettyserver.RequestHandlerV2.messageReceived(RequestHandlerV2.java:138)
	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70)
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564)
	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791)
	at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142)
	at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145)
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296)
	at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459)
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536)
	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435)
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559)
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268)
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255)
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88)
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108)
	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337)
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89)
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178)
	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at java.lang.Thread.run(Thread.java:750)
IIRC there has been some work to improve and update old code to fix some hidden bugs in the network protocols, and I think netty was one of those. It is possible that one bug got missed. It is something the devs will have to look at to make sense of.
Another possibility is some of the settings in your custom conf that may be throwing things off. you have
Device = 192.168.1.116
at the start of your conf but I don't think that is meant to be in there. I have not seen it used before and there is no mention of it in the Defaultrenderer.conf documentation. I could be wrong and that has never been updated but I think it is best to remove it.
Edit: just tried a creating a custom conf from inside UMS and it automatically adds that. I still think you should remove it just in case.
Your custom conf also has the same priority as the Panasonic-Viera.conf so whichever one is loaded first will be used. As both files were included in the logs then both must somehow get used. I think the conf in ProgramData takes priority if it exists but not sure, I personally save my custom confs to the renderers folder UMS's installation directory. Just in case try setting in your conf
LoadingPriority = 2
See if making those changes fixes it for you and if not could you do some more logs with those changes.
This is definitely something for the devs to look at, I have no Idea why it is happening. I have created an issue on Github
I did a bit of testing and can replicate this on my system.
The cause is setting the Device = IP in the custom conf, either in ProgramData or the renderers folder.
If no device IP is set in the ProgramData conf then it will not be used, so for the moment the solution is to save your conf to the renderers folder in UMS's installation folder and remove the device IP from it.
I think the bug has been found and there is a pull request to fix it. I don't know what version it will be included in though.
