Help with restream m3u playlist
Hi
I have playlist tv.m3u
And inside it there are 10 live tvs with the following link as example;
Http://****.com:8080/ch1.m3u8
Http://****.com:8080/ch2.m3u8
Etc..
Using UMS, how can I restream this playlist?
Etc..
Re: Help with restream m3u playlist
This drove me nuts for a long time, looks like openjdk-specific? In any case it's definitely not a plug-and-play solution, your playlist will likely need some tinkering to work with UMS apparently very limited support for this:
So, If you are running UMS on openjdk, this doesn't work (Aug 2022):
audiostream.Test Playlist=UMS Local Audio,file:///STUFF/MP3/test-local.m3u
Now that should work, but it doesn't. Counterintuitively, this _does_ work:
audiostream.Test Playlist=UMS Local Audio,/STUFF/MP3/test-local.m3u
Basically, WEB.conf audio/videostream + URI protocol + M3U = empty folder. UMS (on Linux anyway) chokes on any m3u in the form of a URI, local or remote. INFO logging will show an obscure error about net.pms.dlna.PlaylistFolder.getPlaylistfile not being able to find the modified-by date for the file.
This baffles me because I think the java code actually is
So anything like this won't work in Web.conf:
videostream.Freeview=VBox Channels,http://vbox:55555/ChannelList.m3u
but this will (tested, first d/l using wget, curl whatever):
videostream.Freeview=VBox Channels,/tv/ChannelList.m3u
This case seems the only time a proper URI will _not_ work in a UMS config, and can drive users absolutely batty.
UMS 11.3.0
openjdk version "11.0.16" 2022-07-19
OpenJDK Runtime Environment (build 11.0.16+8-post-Debian-1deb10u1)
OpenJDK 64-Bit Server VM (build 11.0.16+8-post-Debian-1deb10u1, mixed mode, sharing)
PS
(OH and UMS doesn't properly read M3U description tags either so don't have a bunch of metadata in your playlist or it will be very hard to read on the client side
Edit: I forgot to mention another serious UMS limitation of reading M3U -> seems you cannot have "stacking" or a "playlist of playlists" in Web.conf (regardless of the type - .pls, m3u8, etc and regardless of how many entries the 'child' playlist has). So, NO multi-level or "nested" playlists -> every entry on your Web.conf M3U playlist must be an actually transcodable file. The M3U itself can be a list of local files OR web URI but those URI must point to actual media sources. IMHO together with the other problems above you can see how it really needs a lot of work here..
Apologize for the long answer, but I tried to be complete..
public static DLNAResource getPlaylist(String name, String uri, int type) {videostream.Freeview=VBox Channels,http://vbox:55555/ChannelList.m3u
UMS 11.3.0
PS
#EXTINF:-1 tvg-id="" tvg-logo="http://...Edit: I forgot to mention another serious UMS limitation of reading M3U -> seems you cannot have "stacking" or a "playlist of playlists" in Web.conf (regardless of the type - .pls, m3u8, etc and regardless of how many entries the 'child' playlist has). So, NO multi-level or "nested" playlists -> every entry on your Web.conf M3U playlist must be an actually transcodable file. The M3U itself can be a list of local files OR web URI but those URI must point to actual media sources. IMHO together with the other problems above you can see how it really needs a lot of work here..
