Keep loosing connection 10.20.0
schro3f
Post by schro3f »
Im using UMS with a Windows laptop and a PS4. Ive installed the app and chose the folder i wanted to have as the source.
On my PS4 i see multiple folders all with about the same name. Most options however show nothing inside. Only the UMS folder with the same name shows content actually.
As i watch the service randomly drops and i need to restart the server. It happens a lot when i pause the video and try to resume it within couple seconds or minutes. Other times it randomly stops and another restart is needed.
Re: Keep loosing connection 10.20.0
Can you post trace logs so I can see what is happening? See the section in red above.
