[Tutorial] Installing UMS 3.3.0 on Ubuntu 13.10 Server
This was a bit of a pain, so I'm posting what I did here in case I need it in the future.
For this tutorial, I'm installing UMS to /usr/ums simply to keep things simple. I'm not sure if I'm making some sort of Linux etiquette mistake. I've only been serious for about six months and I've only worked with manual installs this week minus webmin which had it's own init.d script.
Please read all steps at least once before attempting to install UMS.
1.You will need root privilages, so "sudo su"
2a. We will need Java to run the program. While the openjava is quaint, it leaves much to be desired. So we'll be using the real thing.
2b. Go to the bottom and add the following line, save and exit nano.
2c. Use this command to get the gpg key
2d. Now, lets update apt-get and install Java (This will always install the latest and remove the openjava)
3. We need some pre-reqs for movie processing:
4. Go to an empty directory, in my case it's root home or cd ~
5. Get UMS (Use the front page for this step)
5a. I downloaded it on a windows machine and smb shared it unto the server in question.
5b. You can also use the following though I suggest using SSH and pasting the link since it's huge.
6. Unpack it using "tar -xvzf UMS-3.3.0.tgz"
7. Move the files to /usr with the following command "mv ums-3.3.0 /usr/ums"
8. Time to make an init.d script. I'm lazy so I'll use the one from Mandrakes post #5551, though I'm modifying a few lines. (NAME and DAEMON) "nano /etc/init.d/UMS.sh"
9. Time to add it to init.d "update-rc.d UMS.sh defaults"
10. Lets turn it on! "service UMS.sh start"
Hopefully it works for you. I'll experiment a bit and see how it works for me. The config file I use is located in "/etc/UMS.sh" That's where I set my folders and what-nots. My /etc/UMS.sh looks like this after I'm done:
edit: Added real java install info, thanks goes to Duin of http://www.duinsoft.nl/packages.php?t=en
nano /etc/apt/sources.listCode: Select all
deb http://www.duinsoft.nl/pkg debs allCode: Select all
sudo apt-key adv --keyserver keys.gnupg.net --recv-keys 5CB26B26Code: Select all
sudo apt-get update
sudo apt-get install update-sun-jreCode: Select all
apt-get install mplayer mencoder ffmpeg mediainfo5. Get UMS (Use the front page for this step)
wget http://sourceforge.net/projects/unimediaserver/files/Official%20Releases/Linux/UMS-3.3.0.tgz6. Unpack it using "tar -xvzf UMS-3.3.0.tgz"
#!/bin/bash
### BEGIN INIT INFO
# Provides: ums
# Required-Start: $local_fs $remote_fs $network
# Required-Stop: $local_fs $remote_fs $network
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Starts UMS program.
# Description: Java Upnp Media Server dedicated to PS3
### END INIT INFO
#set -x
# Author: Papa Issa DIAKHATE <paissad@gmail.com>
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
DESC="Universal Media Server"
NAME=UMS.sh
UMS_PROFILE=/etc/$NAME
DAEMON=/usr/ums/$NAME
DAEMON_OPTS="console"
SCRIPTNAME=/etc/init.d/$NAME
UMS_START=1 # Wether to start or not UMS ver at boot time.
DODTIME=30 # Time to wait for the server to die, in seconds.
# If this value is set too low you might not
# let the program to die gracefully and 'restart' will not work
test -x $DAEMON || exit 1
# Load the VERBOSE setting and other rcS variables
. /lib/init/vars.sh
# Define LSB log_* functions.
# Depend on lsb-base (>= 3.0-6) to ensure that this file is present.
. /lib/lsb/init-functions
# Include ums defaults if available
if [[ -f "/etc/default/$NAME" ]] ; then
. /etc/default/$NAME
fi
# May we run the init.d script ?
[[ $UMS_START = 1 ]] || exit 1
# Some color codes
txtred=$'\e[0;31m' # Red
txtylw=$'\e[0;33m' # Yellow
txtrst=$'\e[0m' # Text Reset
warnout(){
echo >&2 -e ""$txtylw"Warning:$txtrst $1"
running(){
pid=`pgrep -f 'java .*ums.jar.*'`
do_start(){
running && { warnout "$NAME is already running !"; exit 0; }
echo "Starting $DESC : $NAME"
UMS_PROFILE="$UMS_PROFILE" start-stop-daemon --start --quiet --background --oknodo \
--exec $DAEMON -- $DAEMON_OPTS
do_stop(){
running || { warnout "$NAME is NOT running !"; exit 0; }
local countdown="$DODTIME"
echo -e "Stopping $DESC : $NAME \c "
kill -9 $pid
while running; do
if (($countdown >= 0)); then
sleep 1; echo -n .;
((--countdown))
else
break;
fi
done
echo
# If still running, then try to send SIGINT signal
running && { \
echo >&2 "Using kill -s SIGINT instead"; \
echo >&2 "If you see this message again, then you should increase the value of DODTIME in '$0'."; \
kill -2 $pid; \
if [ -e "/usr/share/ums/debug.log" ]; then
count=9
while [ $count -ge 1 ]
do
if [ -e "/usr/share/ums/debug.log.$count" ]; then
plus=$((count+1))
mv "/usr/share/ums/debug.log.$count" "/usr/share/ums/debug.log.$plus"
fi
count=$((count-1))
done
mv "/usr/share/ums/debug.log" "/usr/share/ums/debug.log.1"
fi
fi
return 0
do_force-stop(){
echo "Stopping $DESC : $NAME"
kill -9 $pid
count=9
do
plus=$((count+1))
fi
count=$((count-1))
done
fi
fi
do_status(){
echo -n " * $NAME is "
( running || { echo "NOT running "; exit 0; } )
( running && { echo "running (PID -> $(echo $pid))"; exit 0; } )
case "$1" in
start|stop|force-stop|status)
do_${1}
restart|reload)
do_stop
do_start
force-restart|force-reload)
do_force-stop
do_start
echo "Usage: $SCRIPTNAME {start|stop|force-stop|restart|force-restart|reload|force-reload|status}"
exit 1
esac10. Lets turn it on! "service UMS.sh start"
cred.path = /etc/UMS.cred
uuid = [Not sure if I should hide this]
server_name = "Archive"
folders = /mnt/lp/edit: Added real java install info, thanks goes to Duin of http://www.duinsoft.nl/packages.php?t=en
confusatron
Re: [Tutorial] Installing UMS 3.3.0 on Ubuntu 13.10 Server
Thank you for posting this!!! Worked great on ubuntu 12.04.4 headless server with UMS 3.6.1
One glitch I ran in to, be sure the init.d script is executable (it will give you "unrecognized service" error if not)
chmod +x /etc/init.d/UMS.shRe: [Tutorial] Installing UMS 3.3.0 on Ubuntu 13.10 Server
Thanks! Works great in Mint 18.2 with UMS-6.7.3.
