Problem with JRE
Problem with JRE
Hi all,
I get the following error when starting UMS.
This is the output when I start UMS with Docker on Linux.
My docker-compose.yml
ums | INFO 01:57:16.195 [main] : XBMC
ums | INFO 01:57:16.195 [main] : Xbox 360
ums | INFO 01:57:16.195 [main] : Yamaha AV Receiver
ums | INFO 01:57:16.195 [main] Checking the fontconfig cache in the background, this can take two minutes or so.
ums | INFO 01:57:16.266 [main] Configuration saved to "/root/.config/UMS/UMS.conf"
ums | INFO 01:57:16.365 [main] Transcoding engine "FFmpeg Audio" is available
ums | INFO 01:57:16.428 [main] Transcoding engine "MEncoder Video" is available
ums | INFO 01:57:16.429 [main] Transcoding engine "FFmpeg Video" is available
ums | WARN 01:57:16.430 [main] Transcoding engine "VLC Video" is not available
ums | INFO 01:57:16.433 [main] FFmpeg web filters "/root/.config/UMS/ffmpeg.webfilters" not found, web filters ignored
ums | INFO 01:57:16.434 [main] Transcoding engine "FFmpeg Web Video" is available
ums | INFO 01:57:16.435 [main] Transcoding engine "MEncoder Web Video" is available
ums | WARN 01:57:16.435 [main] Transcoding engine "VLC Web Video" is not available
ums | INFO 01:57:16.440 [main] Transcoding engine "tsMuxeR Video" is available
ums | INFO 01:57:16.441 [main] Transcoding engine "tsMuxeR Audio" is available
ums | WARN 01:57:16.441 [main] Transcoding engine "VLC Web Audio (Legacy)" is not available
ums | WARN 01:57:16.442 [main] Transcoding engine "VLC Web Video (Legacy)" is not available
ums | WARN 01:57:16.444 [main] Transcoding engine "DCRaw" is not available
ums | INFO 01:57:16.444 [main] Transcoding engine "youtube-dl" is available
ums | INFO 01:57:16.497 [main] Using the following UUID configured in UMS.conf: 0e884bb8-5ee6-4008-903a-12ebf66737a2
ums | INFO 01:57:16.837 [main] Web interface is available at: http://172.23.0.14:9001
ums | INFO 01:57:16.878 [main] Checking shared folder: "/usr/src/ums"
ums | INFO 01:57:16.879 [main] Checking shared folder: "/root"
ums | INFO 01:57:18.015 [main] Universal Media Server is now available for renderers to find
ums | #
ums | # A fatal error has been detected by the Java Runtime Environment:
ums | #
ums | # SIGSEGV (0xb) at pc=0x000000000000b8e6, pid=1, tid=110
ums | #
ums | # JRE version: OpenJDK Runtime Environment (17.0.3+7) (build 17.0.3+7-alpine-r2)
ums | # Java VM: OpenJDK 64-Bit Server VM (17.0.3+7-alpine-r2, mixed mode, sharing, tiered, compressed oops, compressed class ptrs, g1 gc, linux-amd64)
ums | # Problematic frame:
ums | # C 0x000000000000b8e6
ums | #
ums | # Core dump will be written. Default location: Core dumps may be processed with "/usr/share/apport/apport -p%p -s%s -c%c -d%d -P%P -u%u -g%g -- %E" (or dumping to /usr/src/ums/core.1)
ums | #
ums | # An error report file with more information is saved as:
ums | # /usr/src/ums/hs_err_pid1.log
ums | #
ums | # If you would like to submit a bug report, please visit:
ums | # https://gitlab.alpinelinux.org/alpine/aports/issues
ums | # The crash happened outside the Java Virtual Machine in native code.
ums | # See problematic frame for where to report the bug.
ums | #
version: '2.0'
services:
ums:
image: universalmediaserver/ums
container_name: ums
restart: always
networks:
- home
ports:
- 1044:1044
- 5001:5001
- 9001:9001
volumes:
- /home/user/tmpssd/:/root/media
- ./UMS:/root/.config/UMS
# - ./Log:/usr/src/ums/
networks:
home:
external:
