V12 no option for custom renderers
Re: V12 no option for custom renderers
I'm not using V12 yet so can't check this myself but it might have been something overlooked while creating the web GUI.
AFAIK the java GUI is still there and you should still be able to set it up there.
I would suggest you open an issue on GitHub for the devs to check what happened to that setting. Post your logs there too as something might be stopping v12 from finding your old custom confs.
To get your existing custom confs working in the meantime you can copy them to C:\Program Files (x86)\Universal Media Server\renderers and UMS will find them.
